20 Most Recent Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Questions & Answers
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Westinghouse... | Answered on Dec 21, 2017
it sounds to me the lid switch problem. when it fails nothing works on some models
Westinghouse... | Answered on Dec 28, 2015
westinghousedigital.com/support/
Westinghouse... | Answered on Jun 12, 2014
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Westinghouse... | Answered on Apr 18, 2014
Drive belt or motor pulley most likely. Many used appliance stores will look at a unit for a fee that generally is cheaper than having repairman come to the home.Upside, if they can't fix it will usually refund your fee. Downside, you need to take the appliance to them. Also a positive: Should you decide cost of repair is not worth fixing it to you, they may give credit to purchase a reconditioned (fixed) machine they have on hand or small amount of cash to purchase a new or used machine elsewhere.
Westinghouse... | Answered on Sep 24, 2013
The back and sides are one piece. The front comes off (two clips under top, one on each side about 2 or 3" in from outside - two screws on bottom directly below clips). The top will lift up on the rear hinges, the front lifts about 0.5" and comes off.
Westinghouse... | Answered on Aug 02, 2012
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
127 questions posted
Top Westinghouse Washing Machines Experts
Colin Stickland
Colin Stickland
Mike
Joseph Hoffmann
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Washing Machines
Most Popular Question
when spining stops stii will spin longer
  • Washing Machines
