Tip & How-To about Sony RMVLZ620 Remote Control
CODE FOR DVD - HOW TO PROGRAM THE REMOTE
DIRECT CODE ENTRY
1.Find the five-digit manufacturer's code for the desired device.
If more than one manufacturer's code is listed, use the code that is listed first. It is recommended to keep a note of the codes for your devices, for easy reference later.
2.Press and hold SET for more than 3 seconds.
While keeping SET held down, press the desired Device Select button, then release both buttons.
The selected Device Select button lights up.
3. Enter the manufacturer's code
The SET indicator flashes three times, and the indicators turn off.
The led will flash 3 times
To cancel the process Press SET anytime.
for codes check the following link
Electronics Equipment Repair Center
Sony RMVLZ620 Remote Control Logo
code's for a Sharp television
Hello
Three digit universal remote codes for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Code Search Method
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search. OK.
Oct 08, 2011 | Sharp Televison & Video
how do i program the RCRN04GR universal remote to a sylvania tv?
Hello
Here is the proceedings for direct code entry.
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method
TIP: Each device key is associated with a type of device-
the TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD•VCR
for DVD players, and DVR•AUX for DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
1. Manually turn on the device you
want to contro
2. Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy.
3. Press and hold the device key you want to program (the
POWER key illuminates).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the POWER key turns off after the first digit).
4. When you've finished entering
the five-digit code, keep holding
down the device key and look at
the POWER key.
Is the POWER key
illuminated?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists
or missed a step in the code entry procedure. Try step 3
again
NOTES
Test the remote with the device to make sure the device
key is programmed with the correct code for maximum
functionality. If some features don't work, try a different code
in the list.
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the POWER key blinks four times, and the
process is exited. The last programmed code under the
device key is retained
Codes to check with Sylvania are:
20035, 20081, 20000, 20043, 20593, 21593
11864, 10054, 10171, 11271, 11314
51563
OK.
Aug 29, 2011 | RCA RCRN04GR Remote Control
my rca remote control is not responding on my insignia flat tv
Hello
Your RCR 03BR Remote has codes to Inisginia TV;
11423, 11564, 10171, 11204
Direct Code Entry
methods, but it's potentially the fastest method.
[1] Manually turn on the device you
want to control
[2] Press and hold the device key you want to program (the
[3] When you've finished entering
the POWER key.
Is the POWER key
illuminated?
again
Jun 02, 2011 | RCA RCRN03BR Remote Control
need code for a dynex tv
The code for the dynex is not listed you will have to do a search:
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
on, then release the CODE SEARCH
button.
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
listed, try doing a device search of the
the steps below.
button.
then stays lit.
the code.
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
Entry and press Cable in step 2 of
Brand Search or Complete Search.
Jan 12, 2009 | Philips PM3S Remote Control
1,466 people viewed this tip
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
