Tip & How-To about Miscellaneous
APPLE iPHONE 6 PLUS GOING HAYWIRE
My Iphone 6 plus was going crazy I think it's called ghosting when it does things without me touching it and when I do it goes nuts here's what I found out and used to cure it, so far this has been successful for two weeks.
open your iphone using online instructions
you will need an opening kit Amazon do them inc a suction cup. a pentelope screwdriver a lever a cross screwdriver also black electrical tape,
open as instructed careful to prize it on the rim, rest the screen open against a folded towel no need to remove it completely,
unscrew the five cross screws holding the display assembly cable, it's a metal plate with 5 screws these are all different sizes I used an address label with the ends folded down onto a sheet of paper with the sticky side up and wrote 1 to 5 around it place the screws on the label to hold and replace in the sequence you choose.
cut a piece of tape to fit the back of the metal plate trim around edges poke a needle through the holes to allow the screws easy access.
replace the metal plate.
close the phone, replace the screws, this works due to the metal plate originally not having a firm hold causing overheating on the cables causing the erratic screen,
I found this tip online on MacRumors posted by Mdsune, and it worked so well I am passing it on.... hope it helps :)
Miscellaneous Logo
the touch screen on my iphone 6
To know if the phone is working, turn the ringer switch on & off. You should feel the phone vibrate.
It could be a battery issue too? Does the screen bulge up a bit in the center? If yes the battery needs relaplacing ASAP if not sooner, otherwise it will break the screen & possibly stuff the phone as well if battery leaks into the phone
May 03, 2016 | Apple iPhone 6
iPhone6S worth buying it?
From what I've seen and heard, if you have a 6, wait for the next phone after the 6s. Anything 5s or earlier go for it!
It really comes down to how badly you want the new stuff and how much money you're willing to spend on tech. Remember that you'll probably want to upgrade to the next one too. Is it worth buying it now, or the next one?
Sep 11, 2015 | Cell Phones
Call Customer Service 1-8O5-465-751O To Fix Issue How can I recover my contacts for my iPhone 3
Do you have backups from your lost iPhone 4?
If not, take a look at this guide about recovering iPhone contacts without backup.
How to Recover Deleted Contacts from iPhone without Backup
Sep 14, 2014 | Apple iPhone 3G
314 people viewed this tip
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
