Tip & How-To about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
How to change belt on Eureka Airspeed unlimited Pet
The screws were easily found on the top of the machine As i found here on Fixya. the screw may be removed by either slotted screwdriver or a phillips screwdriver. great info, thanks. Renetta.
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
how do I remove a lid switch on my washer model #110.20432991 part #3949238?
You will need a 5/16 nut driver, phillips and flathead screwdriver. Remove endcaps on rh and lh side of console by pulling from the top towards you. That will give you access to phillip screws located beneath. Disconnect the lid switch under console, and unlatch gold colored clips attatched to rear panel and cabinet with a flathead. Use a phillip screwdriver to remove lid switch from cabinet and 5/16 nutdriver to remove ground screw underneath main top. Unclip the lid switch from under top. Reverse process to install.
Jun 24, 2014 | Washing Machines
Trying to reverse door swing on Samsung washer WF405ATPASU/AA
Tony, this is a simple procedure and you just need a medium sized phillips head screwdriver. Start by opening the door and removing the two phillips screws that attach the hinge to the machine. Remove the door by lifting up and out. Next, remove the two screws that that you will now see (previously hidden under the door hinge that you just removed). Now, go to the opposite side and remove the two screws that hold the door latch and pull out the plastic latch insert. Also, remove the two screws located (about 4 inches) above and below the latch insert. Now simply reverse the process by securing the plastic latch on the left side along with the two screws (top and bottom). Before securing the door on the right side, lay it down and remove the screw that is used to hang the door (within a slotted hole on the machine) and move it to the top of the hinge (you will see a hole for it). Now simply hang the door on the right side of the machine, and firmly secure it with the remaining two screws. Your door should move freely and latch securely.
Dec 16, 2013 | Samsung Washing Machines
need a digram of taking a dashboard out of a 2005 impala
  • Turn the engine of the Impala off and open its hood. Use a socket wrench to remove the negative cable from the battery.
  • Remove the four screws securing the driver's side kick panel, using a Phillips screwdriver. Use a slotted screwdriver to pry out the kick panel. Remove the passenger's side kick panel the same way.
  • Remove the metal plate from the driver's side of the vehicle under the Steering wheel by detaching its two securing bolts with a socket wrench. Pull the plate off to reveal three electrical connections. Unplug the three connections.
Glove Compartment
  • 4 Open the glove compartment and empty its contents.
  • 5 Remove the two screws at the back of the glove compartment.
  • 6 Pull the glove compartment off of the dashboard.
Center Dash Panel
  • 7 Remove the two screws securing the radio and the two screws securing the A/C unit with a Phillips screwdriver.
  • 8 Remove the four corner screws of the center dash panel faceplate with a Phillips screwdriver. Pull the faceplate off.
  • 9 Use a slotted screwdriver to pull the radio and A/C unit toward you.
  • 10 Reach behind the two devices and disconnect their connections. Pull them out of the vehicle.
Dashboard
  • 11 Remove the two screws underneath the steering wheel, using a Phillips screwdriver.
  • 12 Remove the two screws on the lower right side of the dashboard, using a Phillips screwdriver.
  • 13 Remove the 10 mm bolt from both side panels with a socket wrench.
  • 14 Remove the defroster grille by pulling it out. Remove the four screws along the top of the dash near the windshield.
  • 15 Pull the dashboard off the Impala and detach the two electrical connections. Lift up the dashboard and remove it from the vehicle.
Sep 22, 2012 | 2000 Buick LeSabre
replace bellow seal
Hello.
1 Unplug the power cord. Pull the Whirlpool Duet away from the wall. Remove the screws at the back of the machine using a Phillips screwdriver. Remove the top panel from the machine and set it aside.
2 Remove the soap dispenser from the front of the machine by pulling it out and depressing the button at the back to release it. Remove the soap dispenser bracket retaining screws, using a Phillips screwdriver. Pull the dispenser bracket out of the washer.
3 Remove the retaining screws from the control panel with a Phillips screwdriver. Release the locking clips and flip the control panel on top of the machine. There is no need to disconnect the wiring harness. Open the washing machine door and remove the retaining screws from the door latch, using a nut driver.
4 Remove the outer retaining spring from the bellow seal using a pair of needle-nose pliers to grasp the loop and pull it out. Peel the bellow away from the door opening, using your fingers. Push the bellow seal inside the machine after you release it from the door opening.
5 Lift the front of the washing machine and put a wooden block under it.
Remove the retaining screws from the bottom of the front panel using a nut driver. Remove the wooden block from under the washing machine and lower the unit back to the floor. Remove the screws at the top of the front panel with a nut driver. Pull the panel away from the machine and set it aside.
6 Pull the old bellow seal from the machine. Unplug the white and black hoses from the old bellow seal . Remove the spring clamp from the bellow and throw the old bellow seal away. Rub liquid laundry soap on the groove of the new bellow seal. Push the new bellow seal onto the washtub with the opening for the hoses at the top. Push firmly until it is on tight.
7 Install the spring clamp on the new bellow seal into the groove using a Phillips screwdriver. Plug the black and white hoses into the holes at the top of the bellow. Be careful not to damage the bellow seal. Place the front of the machine on the frame and install the top screws using a nut driver. Push the door latch through the hole and install the retaining screws.
8 Press the bellow seal into place around the door opening and install the spring clamp around the perimeter of the bellow. Lift the machine and place the wood block under it. Install the bottom screws with the nut driver. Remove the wooden block and place the machine back on the floor. Put the control panel in place and lock the retaining clips.
9 Install the soap dispenser bracket and the retaining screws using a Phillips screwdriver. Install the retaining screws on the control panel. Place the top cover on the machine and install the screws with the Phillips screwdriver. Plug in the power cord and push the machine against the wall. Install the soap dispenser drawer and push it all the way in so the tab locks into place.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
323 people viewed this tip
Top Chamberlain Car Audio & Video Experts
Marvin
Marvin
cavs1
James Steuber
James Steuber
Level 1 Expert
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
