Tip & How-To about Washing Machines
Washer Problems Washer noise when spinning
With the growing popularity of front load washers comes a whole different set of washer problems then what was experience with the older top load washers. Front load washers are built quite a bit differently and have many different parts than top load machines.
One of the most common problems with front load washers is that the shock absorbers that hold the tub in place can break. These shock absorbers steady the tub during the wash and spin cycles. It is when the spin is happening that they take the worst beating. It is also during the spin cycle that the breakage will be most evident. If your load is even a little bit out of balance and the shocks are broken, you machine may dance all over the floor and sound like an airplane about to take off. The tub will flounder around uncontrollably and the clothing will come out very wet because of the tubs inability to maintain the spin speed needed to wring out the water.
To see if your machine has broken shock absorbers, remove the bottom cover and look in. About halfway back on either side will be a small cylinder that moves in and out to absorb the movement of the tub. Often the loop that has a pin through it to secure it to the machine will be broken. Sometimes there will be no visible damage, but if you unhook one end of the shock, the slide movement will be very easy and there will be no resistance. The shock should be in and out fairly hard; this is what holds and steady’s the tub of the machine.
The parts are easy to find online by doing a search for “appliance parts” and then entering your model number in the box provided by most websites. The replacement is fairly easy and can be done by most people with a bit of patience and a few hand tools.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Washing Machines Logo
my washing machine has just made a long beeping sound and come up with the code un6? any ideas as this machine is 2 weeks old!!!
To see if your machine has broken shock absorbers, remove the bottom cover and look in. About halfway back on either side will be a small cylinder that moves in and out to absorb the movement of the tub. Often the loop that has a pin through it to secure it to the machine will be broken. Sometimes there will be no visible damage, but if you unhook one end of the shock, the slide movement will be very easy and there will be no resistance. The shock should be in and out fairly hard; this is what holds and steady?s the tub of the machine.
The parts are easy to find online by doing a search for ?appliance parts? and then entering your model number in the box provided by most websites. The replacement is fairly easy and can be done by most people with a bit of patience and a few hand tools.
If you are having problems with your appliance and need to buy parts, where do you go to find them and how is the best way to go about purchasing the parts that you need.
The best way that I have found to buy appliance parts online is to just do a search for ?appliance parts?. When you do that you will have a large number of different websites come up from your search.
You will then need to have the model number of your appliance handy. The make will usually be identified by the model number so just the model is usually sufficient. Sometimes a model number will not work in one site, so try a different site.
When the parts page comes up you usually will have access to ?exploded diagrams? which will help you to identify the part that you need. The pictures on some of the sites are better then others, so look around till you find what you need.
Once you know what you need, check out another site or two, or three. The price you get from one may be quite different from another. Also just because site A had the best price for one part, it may not have the best price for the next part you need. It seems that the different sites will use some parts to get you to buy and then soak you for another part.
Always compare prices with a number of sites to ensure the best pricing.
You can opt for faster shipping at most sites if you are willing to pay the extra costs. Most sites have warehouses in different parts of the country and can get the parts to you in a day or two, even with the regular shipping options.
Thanks for using fixya.
Jul 30, 2011 | Haier Washing Machines
how to remove back of washer
Hello, Thank You for using FixYa. I will be helping you today.If its a front loader just remove all the 1/4 inch screws from the back cover. If its a top load remove the control panel back corner screws flip up control remove two clips unplug lid switch and remove the whole cabinet.The back does not come off the top load whirlpool.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
28,610 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
