Tip & How-To about Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer takes longer than usual to complete the cycle.
Hi.
When the washing machine is working, takes an unusually long time to complete the cycle, that is not usually do to a control unit (CCU) fault, but to the fact that one condition needed to follow on the cycle is not met. The CCU may have to wait a longer time, and will not proceed to complete the cycle.
The most obvious thing to check are the water hoses, checking the drain hose and the inlets. If water is not coming with sufficient pressure, or if one of the hoses is blocked or kinked, the cycle time may take much longer than normal.
Other common problems are the pressure switch (SWITCH, PRESSURE), that detects water level, and the thermostat (on self heating models only).
The pressure switch determines when to stop filling and draining. If the pressure switch is faulty, then drain and filling may take much longer or go on forever.
Check also that water valve and dispenser valve are not clogged. (VALVE, WATER) and (DISPENSER VALVE )
On the water valve there may be a thermistor (not all models), check that the thermistor contact is not disconnected (WATER VALVE W' THERMISTOR) , as the thermistor may also be faulty.
Click here to find all replacement parts and diagrams for your appliance.
Regards.
Ginko.
Maytag Neptune MAH5500B Front Load Washer Logo
not spinning
If everything is working, which I assume is, that is the machine is taking water,spinning etc but not completing the final cycle then you have a fault with your pcb or the the control unit.This is what controls all the unit of the machine to perform a wash, that is it sends the signal to the water valve when its time to take water and sends the signal to the motor to turn etc...
Aug 03, 2009 | Washing Machines
Takes dishwasher hours to complete cycle
How long did it usually take to finish? Do you know which part of the cycle is taking a long time? Like when it starts when you hear it running. How long have you owned the unit? Once I have more information I can assist you further.
Thanks,
Lee
Oct 22, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
3,418 people viewed this tip
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
