Question about Mitsubishi WD62628 62" Projection HDTV
No video in any of the TV inputs
I have a Mitsubishi WD-62525 DLP TV. Today when I turned it on, there was no image only a green screen that looks like a scrambled signal. The sound is good. It happens to all the inputs, cable, DVD, Antenna1 antenna 2, Composite inputs, etc. However, whe i go into the TV set up menu and the Netcommand menus the blue screen is clear and I can go and set up the TV inputs and what not. Any suggestions? the TV is 4 years old.
  • 179 Answers
First try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Posted on Jan 07, 2009
SOURCE:
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Why is the top and the bottom of the tv screen warped.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
There are flickering, rainbow-like color bands running across the screen, especially in the component inputs, not so much using the HDMI input, but still there.
Hi,if your tv is and Lcd rear projection it will be the light engine that needs replacement.Because lcd technology uses 3 chips green,red and blue that create the image and colors.When they start to fail you will get what you are getting color discoloration and rainbows.If your tv is DLp it will be the dmd chips which basically its like the lcd chips but instead of 3 chips its only one that creates the image.Hope this works God bless you!
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
62' DLP WD-62525
Since the set turns on and displays this message we can asume the set is working, so for the next step simply change inputs and see if something comes up, either there is nothing hooked to input 1 or the device hooked to input 1 is off or has failed
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
245 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
