Question about Sansui 32" TV
My Sansui 32" Model LCD32hbw got stuck with the
  • Sansui Master
  • 17,130 Answers
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Posted on Sep 03, 2011
Testimonial: "Many Thanks for your helpful answer"
SOURCE:
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
Apr 29, 2018 | Sansui Televison & Video
Sansui sty1232 it block in standby mode
Try unplugging your TV from the electric socket for a few hours or preferably overnight. Hopefully your TV will then turn on
Oct 04, 2014 | Sansui Televison & Video
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Stuck in standby.
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 16, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
How to enter into Service Mode in Sansui Hard Rock 21 eye model
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 14, 2009 | Sansui DTV2760 27" TV
Television problem
the green led actually means its out of standby.advance the a 1 control to see if you have field collapse.dry jonts on the regulator ics is a common problem too....steve.ps.if the crt heaters are lit ,the psu and line stage is functional...
Nov 05, 2008 | JVC AV-32D305 32" TV
Sansui 32" TV Logo
351 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
