Question about Tomtom GO 700 GPS Receiver
TomTom will not turn on its fully charged - Tomtom GO 700 GPS Receiver
  • Tomtom Master
  • 514 Answers
Try to do a "Boot" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Posted on Oct 27, 2013
SOURCE:
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
How do i charge my tom tom
How do I charge my device? - TomTom
us.support.tomtom.com/.../how-do-i-charge-my-device%3F
TomTomApr 15, 2013 - If you only charge your TomTom while it is in use, it may not charge to capacity. To fully charge your TomTom, it is best to charge the device indoors. Most newer TomTom products can be charged directly through USB, simply by connecting the USB cable or dock to your computer.
Dec 18, 2015 | Cell Phones
How to get my tomtom one N14644 to turn on
First, make sure that your TomTom battery is (fully) charged. Then press the ON/OFF power button ... to turn it on. If it still doesn't turn on, try to RESET it ... using a "pin" (e.g. paper clip) to push up the RESET hole at the bottom of the device.
Jul 01, 2014 | Tomtom GO 700 GPS Receiver
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
My tomtom one no longer recognises the car charger.I have purchased a new one from a dealer and it won''r make it charge.I can only bharge it with my bomputer hook up cable...what can I do now?
Seeing as it charges from the computer
I doubt that it is the tomtom.
I would suspect either the outlet in your car or a posible problem with the lead even if it is new.
Aug 28, 2009 | Tomtom ONE GPS Receiver
My tomtom 1 will not turn on, it is fully charged!
it depends which tomtom one you have! follow the link
below and pick your model # and follow the directions
for your model.
499de9c.gif please let me know if this has helped you.
Aug 05, 2009 | Tomtom ONE GPS Receiver
Tomtom problem
When you turn off the device with power button, you actually set the device in stand by mode, not fully turned off.
This state will drain the battery.
The only way I know to turn device fully off, is to do a reset with paperclip at bottom of device...
Mar 05, 2009 | Tomtom One Europe v2 GPS Receiver
GPS - TOMTOM ONE XL - first time locating position via satellite
The unit was fully charged from the factory. Turned on thwe unit and followed simple directions to position my location. Rest followed.
Mar 30, 2008 | Tomtom GPS
Switch on problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 09, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
80 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
