Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Hi, I have a 52" Sony LCD TV ( Model:
  • Bill Ren Aug 20, 2012
    I have a tv of the same model and exactly the same problem. Where to go to get the solution?
  • shaun taylor Jun 19, 2017
    hi what is the problem, thanks
    shaun
SOURCE:
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
tvservice306
  • 458 Answers
SOURCE: Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Posted on Aug 14, 2009
tvservice306
  • 458 Answers
SOURCE: lines across tv
try cleaning T-CON Board to Lcd panel cable
Posted on Aug 19, 2009
Selvol
  • 115 Answers
SOURCE: My Sony KDL 52S5100 52 inch is great except for
Check the  user manual.  You have the Auto dark enabled.
Or so it sounds. Disable that.
Selvol
Posted on Dec 06, 2009
  • 293 Answers
SOURCE: I have a Sony KDL-46W3000 since January
There isa problem in CRT Board.Loose connection problem in vertical section.Need for resolder the board.
Posted on Oct 09, 2010
My sony bravo 52 inch model # KDL52W5100. HAS A DARK SHADOW IN MIDDLE AND BLURRY RIGHT SIDE. BUT THEN IT FIXES ITSELF AND 2 TO 3 DAYS DOES IT AGAIN
The part failing is called T con board , http://www.tvpartsinstock.com/sony-kdl-52vl150-kdl-52w5100-kdl-52w5150-t-con-board-lj94-02676j-15589084
, if your handy you can swap it out yourself . or pay a shop more then the TV is probably worth ( not recommended )
cost 65.00-70.00 they are a lot of screws and shielding to remove to get to the main PC board . Hope that helped a little
Feb 24, 2016 | Sony Televison & Video
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
The picture is too big for the screen and i can't get it reduced
Change aspect ratio of screen through screen format option in Menu.
Hope this will fix your screen size issue in Sony KDL-52W3000 tv.
Thanks.
Dec 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
