Question about Cyberhome DVR 1600 DVD Recorder
Unknown Disc Hi. I am another very frustrated Cyerhome DVR 1600 owner. I purchased this unit from Target and soon after sent this unit back to Cyberhome for warranty repair back in 2006. After receiving it back, I went overseas to Iraq and never had a chance to use it. Upon my return, I hook it up and it shows the same error, "unknown disc". I recently discovered that Cyberhome has gone out business and disappeared entirely. I have gone online to try to get a repair option before I totally torch this DVR! Please help-I am open to any solution(s) that you may have. My email is esamuelusa@yahoo.com. Thank you for your time. Eric Samuel
    Brigadier General:
  • 5,158 Answers
If you have the manual check to see if you are using a compatable disk for the device..... what was the original repair for ?
Robert
Posted on Sep 25, 2008
6ya staff
SOURCE:
No matter what kind of disc is put into my DVR 1600 Recorder, a "no disc" message is given
Ok, in my experience over the years, most often when this type of problem exists it is always the laser unit, and or the quadrant detector, essentially the "Laser Head Assembly", this has faulted. (Or the associated drive circuitry).
Replacement is your only option.
If you wish to have it repaired, please ask for a 'Quote" before proceeding with any repair work.
Oct 03, 2010 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200 dvr
First the Dvr 1200 has hard ware failure in it the tray eject unit and the display is failed ........................................it can fix in local service center.............................
Second your New DVR 1600 check the format of the dvd is it compactiable with format of the player and if face the same problem get it replaced as this is new player manual opening could lead no warranty on the player , it better to get it replaced ..
May 30, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
No disk
Hi. I have this problem with my unit. After a lot of research on the net it apperars that this is caused by problems with the laser pickup. The laser is either dead or is on its way out and doesn't have the strength it needs to read sensitive DVDs but is OK with Audio CDs.
A lot of CyberHome units have this problem due to the poor quality of the laser pickup units they use. I have been told that they have since gone bankrupt. If it is still under warranty then it you may be able to get it repaired but otherwise it may be cheaper to get new unit.
Hope this helps
Sep 10, 2008 | Cyberhome DVR 1600 DVD Recorder
Unknown disc error
Get a good dvd cleaner I notice that alot of people have this problem. The optics get dirty and it won't read the dvd anymore,
some reason not play no 2 zone dvds.
Jan 24, 2008 | Cyberhome DVR 1600 DVD Recorder
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
My is a Cyberhome is a DVR 1200 DVD player
Try unplugging the unit from its power supply. Wait a few moments and then plug it back in. I have the same unit and that is what I have had to do. I am afraid that we have purchased junk. This machine "works" some of the time. It usually functions well as a player but fails on numerous occasions as a recorder.
Dec 03, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
128 people viewed this question
Top Cyberhome Televison & Video Experts
Demonic-2011
Demonic-2011
Kahn Chaddock
Level 1 Expert
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
