Question about MicroBoards PF-3 InkJet Printer
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the correct color.
  • 844 Answers
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Posted on Dec 27, 2011
6ya staff
SOURCE:
Fuzzy printing
Try a reset to factory defaults. Or a hard reset. Or driver reinstall. If nothing works then you have a physical issue with unit.
Sep 06, 2017 | Konica Minolta bizhub C250 All-In-One...
My printer does not print the test page the text. It only print the microsoft logo.
Most of the "text" on the "test-page" requires that the BLACK ink on the printer is working correctly. Refill or replace the BLACK ink-cartridge.
May 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Every other word either red or blue
Please follow these steps and then try to print :
For winows system :
1. Click Start, Settings, Printers (Windows XP: Control Panel, Printers and Faxes).
2. Right click on the Lexmark printer icon and select Properties.
3. Select the Printer Settings tab (Windows XP: click on the Printing Preferences button) and click on the Change button.
4. Close the I Want To menu and select Print Color images in Black and White.
5. Click OK to confirm the new settings.
For mac system
# Load plain paper into the printer. Open the Page Setup screen and select the required settings.
# Then open the Print screen and customize the image printing settings as follows:
1.
2. From the software application, select File, Print. From the Printer pop-up menu, choose your printer model and then continue.
3. From the pop-up menu in the upper left corner, choose Color Options.
4. From the Document Color pop-up menu, choose Black Only.
5. Click Print.
Mar 20, 2009 | Canon BubbleJet i560 InkJet Printer
Print images look like a rainbow, going from blue to red to blue to red etc.
I am on my way to a couple of appts. I waill answer early afternoon, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 06, 2008 | Ricoh Aficio CL3500N Laser Printer
Red text and lines appear in Black text
The red line is indicating a HYPERLINK to the email address of the user name, or other linked text in the Email.
If you are printing a program, you will not be printing anything with a hyperlink, so that should not be an issue.
Apr 27, 2008 | HP PhotoSmart 7660 InkJet Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Prints black on test page, but not when a job is sent to the printer
make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Oct 18, 2007 | Canon BubbleJet i560 InkJet Printer
Does not print pictures
hi suvi please tell us more about your computer and printer setting.. However, i have some question.. 1) Does your printer print another logo or any other picture correctly like before? & 2) Which software did you used to print your logo? Thanks, waiting for your response
Aug 29, 2007 | Epson Stylus C46 InkJet Printer
Printer Ignoring Black Text
Assuming the print tests you've done so far are built into the printer: Could be worth printing a test page from the printer properties box (which you can get in XP from the START menu, Settings, Printers & Faxes, then Right click on the printer you want and select Properties from the dropdown. If the test page is OK, I'd try printing from a few different applications to see if that narrows the problem down. If the test page has the same problem, then you might try reinstalling the printer driver. A.
Feb 01, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
MicroBoards PF-3 InkJet Printer Logo
82 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
