Question about Kenmore Elite HE4 Electric Dryer
Washplate problem Kenmore Elite Calypso washer
My 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. I have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand. Thanks!
  • leejen Oct 14, 2008
    I have a Calypso action Kenmore Elite washer. It will not nutate unless I raise the entire top of the washer and pull the center agitator into offset position. It works good for that cycle. Once the plate levels for spin or other requirements I must reinitiate the manual pulling again. I have duplicated the the problem both with the nutate key dance test and the 99 count test. I am a very accomplished mechanic of industrial machinery and would like to get some technical data for this machine. No other malfunctions occur other than stated above. The model # is: 110 21282 000
    Thank you for any assistance.
  • Rach50 Dec 23, 2008
    Problem: The washer displays FL. I don't know what this means, however, I just went thru your troubleshooting. Removed the base plate on the bottom, took off the black hoses, and after cleaning up all the water, finding my socks, I thought I has succeeded. Not so fast, I started a load again, and when it got to the rinse cycle, it displayed FL again! Please help. Do I replace the pump next? or should I remove more hoses to clear any other thing that may be hanging it up?
    Rachel
  • 750 Answers
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Posted on Oct 13, 2008
SOURCE:
My kenmore elite calypso washer is making a buzzing sound one minute into the wash cycle. It is about 9 years old. Should I fix it? How?
Sorry you had the bad luck to buy a calypso washer,probably the worst washer ever made! I also had the misfortune of owning this washer from hell. My washer had the same sounds as you described and in my case it was the water pump, which in this machine is separate. It wont be to long before you will have a total failure and then the fault light will come on.I am on my third pump and looking for a new one. Good luck on this one.
Dec 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Kenmore Elite HE4 Electric Dryer Logo
953 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
