Question about Sony BRAVIA KDL-46W3000 Television
Sony kdl-46w3000 3 blinks
I got the 3 blink code for this set. The green power LED will come on with no relay activity then go into stand-by. The code is a "power error" so I ordered a new GF1 board from Shop Jimmy. The new board was installed and fried the relay upon attaching the power cable. It would do nothing after that. Re-installed the old GF1 board and it is back to 3 blinks. I assume the new board was defective since the old one powers then goes into stand-by. Any thoughts on this??
    Top Expert:
  • Sony Master
  • 76,099 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 05, 2017
3 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
  • 541 Answers
SOURCE: connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Posted on Oct 24, 2009
Testimonial: "Thanks for your help. George"
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Green led in ON but red led in blinking,after so many blinks of red led the both lights ,red and green,gone off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 15, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
TV not power on. I replaced PS board 1-878-599-11. with new one, Green light on front cycles every 10-15 seconds. took back off and Relay RY6000 sets and resets. Any suggestions? no picture, no sound.
Oct 12, 2015 | Sony BRAVIA V-Series KDL-46V5100 46 in....
My TV does not power up,Sony KDL-52XBR9,it tries to trigger the relay on power supply board G7N 4 times(RY6101) then it turn to blinking red LED 10 times per cycle.Is it power supply fail?which part?
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 12, 2015 | Sony KDL-52XBR9 52 in. LCD HDTV
Red light is blinking 6 times
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 04, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Latest software update kdl55nx720
Oct 11, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony bravia 22EX320 reboots and blink 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Apr 19, 2014 | Sony BRAVIA KDL-22EX310 22" LED TV...
Sony CRT TV type:DRC-MF DR34M69, long time to ON, LED stand by blinking red and green, how to solved this problem? Thank You.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 04, 2014 | Televison & Video
Sony BRAVIA KDL-46W3000 Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
