Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
It was working fine then no picture dark sceen sound work fine
The set was on then vertical colored bars I turned it off and on now the sceen is dark but not black the sound and channels work fine
  • 1 more comment
  • dbartley Oct 19, 2008
    No The menu/OSD does not come on my sourse is Rogers cable digital box
    No OSD/MENU does not dispay Connected component.It was working fine for two years prior to this issue.
    Thanks
  • Anonymous Nov 06, 2008
    When I turn the tv on, at first I get like 4 vertical blue bars, then when the tv actually comes on, as dbartley states, the picture is very dark, the motion is very blurry or slurred, and if you switch to the next channel, its very slow to show the picture. It doesn't matter how the tv is hooked up. 2 months ago, I had cable, via coax. That did it. Also, my xbox and ps2 did it via av jacks. Now I have satellite through hdmi cable, and it also does it. Have already done the factory reset. Any solutions?
  • 320 Answers
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Posted on Oct 19, 2008
  • 1 more comment
  • Anonymous Oct 19, 2008
    Does the OSD/Menu on the TV itself display? How is the cable box connected to the TV? Is it connected composite, component or HDMI?
    I would try a factory reset before anything else. Be aware that in doing this you will lose any saved settings on the TV. To perform a factory reset, turn the TV on, hold the up button on the remote control down and, while holding the up button down on the remote control, press the power button on the TV. When you release both buttons, the tv should power down, and then power up and ask you what language you want. If this does not fix the problem, you will likely have to have a technician look at the set. I would also check all of the other inputs and see if any of them work. But, with no TV OSD, it is probably in the TV and not an easy fix, that is if the factory reset does not work. Good Luck!
  • Ieti Tiatia Nov 30, 2018
    I have this same problem. But my osd comes up fine. My standby light dosent flash. What would my issue be. Everything was working fine and all cables are correctly inserted
    New Friend:
Sony bravia model no, klv-v40a10 tv on sound ok no pic......plz my solve the problem
Posted on Sep 14, 2011
6ya staff
SOURCE:
SD Tech: VERY dark picture with several black vertical bars
This set like most of these has 3 hidden Menu's=
1. Adjustments (stay out of that one)
2. Convergence (like the one in customer menu but better)
3. Option Menu**************
It will not correct the convergence circuit problem as those adjustments are stored in the Digital Convergence unit on the main board.
What it will do is a hard reset of the TV---everything back to factory original--can cure odd issues: no sound, video issues, you name it.
If you want I have found a site that has this for each of these sets--IT CAN ONLY BE DONE WITH THE ORIGINAL MITSUBISHI REMOTE.
I can get you a link to the site and manual for this set--since I never trust certain sites I do not download that manual but you can look at every page and copy paste to your computer the information needed for the OPTION menu and how to do it----stay out of adjustment menu as one wrong move and poof!
use the make a comment button to let me know what you want to do and I will help.
Mar 26, 2012 | Mitsubishi Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Astar ltv 19bs lcd
If you still have the TV, the remote has to be re-set. Hold the Enter button down approximately 10-seconds. It should re-set itself.
Jan 23, 2008 | Astar LTV-19BS 19 in. LCD Television
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Akai Plasma 42" PDP4294
I had the same problem I was told to unplug then reset but still no luck. Mine have been broken since Aug 2006 and seems like it's so hard to find somebody to fix it. Please let me know if you fix yours.
Jan 21, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
1,037 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
