Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki brute force 750
I flooded my 4 wheeler under water now it spits and backfires.
  • Steven Murdock Oct 31, 2008
    I also flooded my 07 Kawasaki Brute Force 650 4x4i, after getting it out I drained the oil, my belt, and one cylinder by removing the spark plug. Still no go, is it the carbs? Anybody with any ideas on how to go abouts reviving it. I would very much appreciate it. You can contact me by e-mailing me at:
    stevenmurdock@hotmail.com
    Thank you.
    New Friend:
My 2009 brute force 750 come to a hault. Only 400ml of oil in it. not enough to engage low oil presure light. No oil leaks and oil dosn't seem to be burnt.(baffle is pretty clean) any one no where oil could have gone? only done 50 hours. the result to this was main bearing shattered through motor.
Posted on Jul 25, 2010
  • 4 Answers
Try to drain carb
water probably got in through air box and carb vent hose
drain and flush carb
replace spark plug
spray contact cleaner in carb throat through air box
Posted on Dec 19, 2008
    New Friend:
  • 69 Answers
Good chance u have a bent rod, bent valve. Need to take to shop to get checked out.
Posted on Nov 25, 2008
SOURCE:
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Brute force 2009 750 runs but will back fire an stop
How long since the oil has been changed? Is the oil level OK? It sounds like you have a sticky valve that hangs open once in a while.
Jul 31, 2014 | kawasaki 2009 Brute Force 750 4x4i
Where is the thermostat located on a 650 kawasaki Pririe 2003 4 wheeler
Follow the top radiator hose til it gets to the engine...that housing has the thermostat under the cover
Jul 16, 2014 | Yamaha Kawasaki Genuine Kvf750 Brute Force...
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
I have a 2005 brute 750. It will start and idle fine, but when you give it gas it begins to miss and backfire through the carbs and tail pipe. I just took the carbs off and cleaned the jets, new plugs and...
If it just crossed the 100hr mark the Check Belt function of the ECU will be activated. Perform the Belt Light Reset if is crossing a 100hr mark on the odo
Jan 20, 2018 | kawasaki 2005 Brute Force 750 4x4i
Kawasaki brute force 750 2005, idles fine, but when you press the throttle it backfires, is this due to a carb problem?
Your jetting on the carbs are wrong.
if you want more info on the jetting and how to do it along with some GREAT info, check out highlifter.com/forum
Dec 11, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
1,411 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Steve Worthey
Wayne McNeil
Warren Kareroa
Warren Kareroa
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
