Question about Samsung Washing Machines
What does ds mean on Samsung high efficiency washing machine
  • Samsung Master
  • 6,046 Answers
A dS code means that the door was opened during the cycle. (At least this is true for the WF210ANW/XAA washer.) Close the door tightly and restart the wash cycle.
If the error persists, you probably have a problem with the door latch.
Samsung has the manual and trouble-shooting FAQs for many of their appliances here: http://www.samsung.com/us/support/ . Click on Washers & Dryers (in the rightmost column) then use the drop-down menus to select Washers and then the model.
I hope this helps. Please add a comment with the model of your washer for additional assistance.
Posted on Mar 21, 2012
6ya staff
SOURCE:
What does SUDS mean
It simply means you have used too much detergent and the only way to correct it is to run 2 or 3 loads empty with just COLD water.
Aug 09, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Timer lot is on- won't start
the timer s a delay in starting your wash load
Sep 25, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
Washing machine stopped with the code SE flashing - pls advise thx
are you sure is SE and not 2E because 2E means you need to replace the pcb board wish is poor power on motor.
Jul 31, 2011 | Samsung WF306BHW High Efficiency Front...
The door on my Samsung Washer won't latch. It then displays DS error. Seems the roller in latch is down therefore not allowing door to close all the way.
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Mar 13, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
Washing machine flashing de
I haven't seen a DE is it maybe DC? these are the known codes
DL - Door unlocked when washer is running DS - Door is open when washer is running NF - Washer tried to fill but was not successful due to clogged water lines or closed water valves. ND - Washer is not draining it can also mean that the unit senses a small clog or frozen hose. DC - Unbalanced load prevented the washer from spinning. When the weight of the laundry is about 1kg the center of the weight gets shifted. redistribute the load and restart or add more clothing.
SUDS - Too many suds are detected, the unit will be put on hold until the suds are reduced the it will go back on. when it completes the wash it will flash END and SUDS. make sure you use HE (high efficiency) detergent
Oct 10, 2010 | Samsung Washing Machines
Washer won't spin & drain, "dc" showing
Hello Nancy, this is what I've retrieved right from Samsung. "dc" on those washer's mean this, In the words of ( Samsung ) the manufacturer..."Unbalance or cabinet bump is detected during final spin which prevents it from spinning over 400rpm". ( Never exceeds 400rpm due to unbalanced load ). Then they (Samsung) say, " not enough load. Put additional items to equal load" or "excessive suds from too much detergent or wrong type/non-high-efficiency, use less or switch to high-efficiency ("HE"). I would check for too many suds from either too much "HE" or you're using the wrong stuff...regular detergent/non-"HE" let me know if I can assist you further and thanks for coming to "fixya" today. Good luck macmarkus :)
Apr 08, 2010 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Washing Machines Logo
1,111 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
