Question about Panasonic Cameras
How do i factory reset my panasonix lumix dmc-fz45
Camera keeps coming up with system error zoom, how do I reset back to default settings?
  • Panasonic Master
  • 6,771 Answers
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
Posted on Apr 05, 2012
6ya staff
SOURCE:
SGNath
Sujith Gopinath
  • 170 Answers
SOURCE: I would like to know
Press the Menu/Set button and from the Setup menu, select Reset.
Posted on Feb 04, 2009
Vladimir Z
Vladimir Zavodny
  • 86 Answers
SOURCE: Describe your Panasonic Lumix DMC-FZ18 Digital
the zoom in the camera is manual, are the lenses moving inside, when you go from 35 to 420 mm?
Have you dropped your camera or has is experienced a shock of some kind? In that case you would need to send it for repairing the lenses, do not attempt to do that on your own.
Posted on Oct 18, 2009
Ty Price
  • 11967 Answers
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Posted on Aug 23, 2009
Anonymous
  • 18 Answers
SOURCE: panasonic lumix dmc-fx37. Two error messages are
sounds like the focus and (Optical Image Stabilization)drive motors are bound or broken, sadly this normaly means new camera, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well ya know, they will normaly repair or replace it as long as it is due to manufacture defect.
Posted on Mar 16, 2010
Testimonial: "thanks for your help. "
lock123
Andrea Lock
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Can you restore a Lumix DMC-FZ70 back to factory settings
Yes, the reset instructions can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/DMCFZ70_ADV.PDF#page=70
Apr 19, 2014 | Panasonic Lumix DMC-FZ70 16 Megapixel...
Factory reset Lumix DMC-FZ45
Remove the battery for 20 mins. replace the battery.turn on and go to the camera's Menu scroll through the settings to the Date & Time, set the current date and time.
Apr 19, 2013 | Panasonic Lumix Cameras
Error in the system (OIS)
Try turning off the "shake control". Does that help? Also, go into the menu and find "reset" to return to factory default settings.
Oct 12, 2011 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
I want to reset my lumix panasonic fs16 but afraid of what it will do to my camara
It will reset the camera setting back to the factory default settings the camera came with.
Jul 19, 2011 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
How do i factory reset my panasonix lumix dmc-tz7
The "reset" function is found in the camera's menu system.
Jan 13, 2011 | Cameras
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
Jul 11, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
My FZ18 will not zoom. Stuck at wide angle. A msg will sometimes flash when first turned on...CAMERA WILL RETURN TO PREVIOUS ZOOM SETTING...or something like that. It functions otherwise. I have been thru...
Set camera to P mode.
Press [MENU ] to display the [SETUP] menu
and select the item to set.
The [REC], [CUST. SET MEM.] or [SETUP]
menu settings are reset to the initial
settings.
• [FAVORITE] (P98) is fixed to [OFF] and
[ROTATE DISP.] (P97) is fixed to [ON].
• If the [SETUP] menu settings are reset,
the following settings are also reset.
See page 22 in manual.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ18K
This should reset whole camera to factory setting.
Cheers.
Jul 08, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Jan 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Cameras Logo
2,314 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
