Question about Sony Bravia V-Series KDL-52V4100 LCD TV
I have a sony kdl-52v4100 tv. It had a power surge and now blinks 2 times. I changed the power supply with a known working one and it burnt it up. I changed the power supply again and the bu main boar
The original power supply that still blinks 2 times has no low voltage dc output other than the 3 volts. when the 3 volts is jumpered to the power on terminal the relay clicks but still no low voltage. I am not interested in trying to fix the power supply as much as I am trying to replace the board that is most likely shorted. I realize that another power supply board is needed but used boards are relatively cheap and I would love to have this tv working again. Any suggestions?
    Top Expert:
  • Sony Master
  • 76,140 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 03, 2017
3 Suggested Answers
SOURCE:
  • 8909 Answers
SOURCE: Sony Bravia KDL-40S3000...standby red light blinks
There may be no horizontal ouput, Check C515 & 516 and the jungle IC, IC206.
Hope that helps
Posted on Feb 28, 2011
  • 17 Answers
SOURCE: Sony Bravia LCD KLV-32U300A Symptoms: ~ powering
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
Posted on May 21, 2011
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
I have a Sony 52 inch kdl-52v4100.had a power surge.now tv will not power up
Tv might be fried.Or one of the circuit breakers Is popped. Maybe try a different electrical outlet.
Apr 20, 2015 | Sony BRAVIA KDL-52V4100 52" LCD TV
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
My sony kdl 40 u 2530 e is not staring properly. the red led signal blinking 4 times periodically .any idea about the problem? If i turn off tv for hours then it starts for 2 minutes and again the same...
The tv power supply board have problems and the caused,check the tv power supply board have it fixed or services by u or tv tech.most likely those capacitors parts are dying on the tv power supply board like bulging or puffing up.Take the tv aparts,check the tv power supply board that board where the power a/c cord plug into it.Carefully check for capacitors parts for bulging and puffing up on to it tops.Changes all these dying capacitors,tv should be work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony kdl-40v3000 standby light blinks 10 times. anyone got an idea what this means?
Follow these steps and check if help to resolve the issue:
1. Disconnect all the attached external device (if any) and then try turning ON the TV.
2. Remove the surge protector or power strap (in any), directly connect the TV to a working Power outlet and check.
3. Try changing the power cable (if possible).
4. If the issue persists then Service may require to resolve it.
Good Luck!!!!!!!!!!!!!!!!!
Sep 12, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia V-Series KDL-52V4100 LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
