Question about Electric Lawn Mower
Electric lawnmower battery won't hold a charge
Earthwise electric lawnmower was great for the first year. Removed the battery and stored it inside for the winter. Put it back in the mower and allowed it to fully charge. Charge only lasts about 3 minutes and then it dies.
  • Lisa Withrow Jul 06, 2013
    Ditto. I'm on my third battery in 4 years. Now the charger won't even show a light.
Charger for same does not show any lights..so should i assume the charger is not working?
Posted on Jun 03, 2018
3 Suggested Answers
SOURCE:
walesarumi
  • 6993 Answers
SOURCE: how to install new battery in earthwise 60020
Locate the battery on your lawn mower. It will be under the seat or under the hood.
Remove the old battery by using the correct socket or wrench to remove the nuts attaching each cable to each terminal.
Examine the battery for any restraining hardware and if present, remove using a wrench or a screwdriver.
Carefully lift the old battery out of the mower. Using a wire brush and a solution of water and baking soda, clean off the cable ends.
Lower the new battery into place and attach the black cable to the black, or negative terminal, and the red cable to the red, or positive terminal. Reattach any restraint system.
Good luck.
Posted on Apr 17, 2011
bigguy810
  • 448 Answers
SOURCE: need the battery diagram for
if you have a black and white always remember black is always negative
you wont have any problem with that but let me no what you have
so i can solve my own curiosity
i hope this helps you
bob
Posted on Jun 17, 2011
Where can I buy a rectifier for a 15 amp earthwise lawnmower
Hello Condo Sarto,
The first site that popped from an internet search...
Sears Parts...
searsparsdirect com
Jun 27, 2016 | Electric Earthwise Corded Lawn Mower...
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
Nwz-w262 battery will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Batteries won't charge
are the batteries over 4 years old? these particular batteries will lose their ability to hold a charge over time, and charging them will not have any effect. you could also have the charger tested. batteries plus stores can test the charger and the batteries for you.
Aug 09, 2011 | Jet 7 Portable Power Chair
What does the red blinking light on battery meant ? It is on The Electric Earthwise Lawnmower.
Red blinking light according to test at Batteries Plus means that the charger is kaput.
Sep 29, 2010 | Electric Earthwise Corded Lawn Mower...
Electric Lawn Mower Logo
1,278 people viewed this question
Top Electric Garden Experts
Steve Oakes
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
