Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Glass surface of warming zone/plate smashed.
Our glass plate has totally smashed (due to a toddler accident) and we need to replace it. How do we go about it & who do we contact.
    President:
  • 1,462 Answers
It is an expensive job so it is worthwhile contacting your household insurer to see if it is covered
Posted on Nov 26, 2008
6ya staff
SOURCE:
How to change door mirror on Vauxhall insignia
If it is just the glass, the back plate the glass sticks to is only clipped in. You will probably need to smash the old glass when you GENTLY lever the old one out. Check the back of the plate as the heated versions have a wire connected to it. The picture is for a 2008 but the set up is exactly the same.
1a7100a2-56b1-4ac8-b449-57e9d76c44e3-snlfx3wo0j1p2eed3bqtncbu-5-0.jpeg To replace the whole assembly you need to remove the trim and the door card. The bolts mount the housing from the inside through the door. The trim and door card will be held on with small screws and push in clips. Some of the screws can be tucked out of sight so make sure you don't miss any. The push clips should 'pop' out if GENTLY levered out.
Jan 11, 2018 | Vauxhall Cars & Trucks
Warming zone on glass top whirlpool gold, will not turn off, remains hot no matter what.
Disconnect the power from this range! Have a qualified service person come and check it out/repair it. This is not a job for amateurs.
Jan 02, 2018 | Whirlpool Refrigerators
How do ya cut plate glass and what tools are recommended?
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Nov 19, 2014 | Building Materials
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Smashed screen
It may still have a warranty try calling the supplier. :D
Feb 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
How hard is it to replace the inner glass in the oven door?
not a train smash, locate screws to seperate the two door halves to allow access to the inner glass. remove screws and plates holding the broken glass. clean then place new one in possition and tighten screws comfortably tight.(dont over do it).Reassemble door.
Sep 14, 2009 | Ovens
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
GE 6 QT crock pot inside dish
I accidently smashed the bowl insert of my 6 quart crockpot Where can I purchase a replacement one?
May 15, 2008 | GE 106661 4.5-Quart
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
237 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Thomas F. Schneider
Archie Ferrarini
Archie Ferrarini
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
