Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
It starts off by making a strange noise. Like a long hum and a click. As if the compressor is attempting to come on but can't. It will do this for a couple of days then it will no longer cool or freeze. The fan is working, but blowing hot air. Then about 3 days after it has stopped it magically starts working again..and will for about 2 weeks. We have cleaned the coils as suggested in the manual, but it did not do anything to help it. Is it possible that the thermostat is going out? Our refrig is only 2 years old. We bought it brand new when we bought our house. What can we do to fix this problem?
  • 2 more comments
  • cyber7blue Nov 18, 2007
    I have the same problem. It started making an unusual noise from the freezer a couple of days ago and then it stopped working. There was a long hum and now we hear clicking sounds frequently. It no longer cools or freeze. The fan is also working, but blowing hot air. We have followed the troubleshooting section in the manual, cleaned the coils, checked the water filter on the base grill, checked the air flow mechanism behind the freezer, checked the control box and reset the defrost timer, but it still did'nt do anything to help it. There were no obvioius parts broken. We have a strong feeling it might be the compressor because of the frequent clicking sound, but would like to find out how to test it. If there's a leak from the compressor, how do you detect that? It does have the blue indian logo. Any suggestions or ideas would be greatly appreciated.
  • Anonymous Dec 18, 2007
    Sounds like the same thing to me as what mine is doing. I have the refrigerator with freezer on the bottom. The freezer stops freezing. I was told by dealer to turn the unit off completely and then turn it back on. It works for about two weeks, then starts again. I am now on the third load of food that is being ruined. I had a service repair man come out and at the time the freezer was working. He told me he could not service it until it stoped working so he could find out what the problem was. This happens on the weekends, nights, mornings. He replaced the computer board for $200.00 and told me he would not guarante it. It went out again two weeks later. What am I suppose to do? Have the guy live with me. When I called the last time it was a weekend and he was out of town. How am I suppose to get this issue fixed. The refrigerator is only two years old and I am out $200.00 and still have a broken refrigerator.
  • enthuiest Jan 20, 2008
    I also have exactly same problem? can you share how your refrigerator pronblem got fixed?
    thanks!
  • Gennady Prosmushkin Jun 23, 2008
    I have the same problem Looks like the thermostat problem. It can not be reset right away cause there is a capacitor which holds corrupt memory. After about 24 hours it resumes working. It mu theory. I am waiting for a repaireman foi now.
  • 237 Answers
It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Posted on Jan 08, 2007
It IS the compressor. My Maytag had a Tecumsei (sp?) and it would work and then not work ...this went for over three years. I finally googled it to death and found out all sorts of information. I called Maytag and they denied it. I fought with them. Finally they sent someone out. The guy who fixed it told me I had a Tcumsei and they are famous for dying after the first year.
This really ticks me off. I spent hundreds of dollars on prior repair people coming out not to mention the cost of all the spoiled food for our family. It always seemed to die right after I went food shopping!
There should be a class action suit for this.
Posted on Sep 17, 2009
FYI anyone with this problem be aware Maytag denies it is a problem. Call and insist it is a product defect, or they will attempt to charge you. if you have already paid, demand your money. class action is around the corner on this one, as they have had problem on other models that use the same basic design, and have been forced to make repairs at their expense
Posted on Mar 17, 2008
Guys it is likeley the issue is the supply voltage to your house is too low and the compressor has been designed too lean so it cannot generate the torque to start the compressor. This causes the small overload "klixon" to open protecting the compressor from fusing. This effect can be noticed when the compressor HUMMs for 3 seconds and then the klixon goes "click"
To fix this make sure your mains voltage is no lower than 230V AC+10% or -5% else claim damages from the supply authority with the reaaosn being compressor start failure due to stalling induced by low voltage .
Tecumseh make very good compressors and are probably incorectly manufactured for the application by the appliance amnufacturer ie over charged with gas by a few grams.
The cheapest way to fix it is to get a fridge techician to recover the gas weigh it and make sure it is exactally what is on the fridges compliance tag. The other way is to drop a bigger compressor in.
Posted on Dec 05, 2009
    New Friend:
I think they should have a recall on this piece of ..... refrigerator . I will never buy a fridgeraire again.it **** 1 and a haLF YEARS OLD BULL
Posted on Jan 16, 2011
WE have the same problem...I think the only solution sadly is to get rid of the LG and buy a better fridge....sad too because they are suppose to be environementally efficient but not for long and then they end up in landfills because they basically stink.
Posted on Jan 13, 2008
Don't buy anything frigidaire, we spent over 3k on appliances for our home. The dishwasher lasted 6 months, has been repaired several times in 3 years and has never worked properly since it was 6 months old. The stove needed a control panel after 18 months, we had no oven while this part took weeks on backorder. Our refrigerator lasted until a month after our 3 year warranty expired and is now having these same issues as described. Just our luck we have the compressor with the indian head logo. The best appliances we bought were our whirlpool washer and dryer and our 1985 roper refrigerator that was kept as a spare, but never fails! My family will never invest in frigidaire and I suggest you reconsider as well. They no longer make the quality products they once did. I don't think it was poor luck that all of my frigidaire appliances crapped out before or just at the 3 year mark.
Posted on Jul 24, 2007
    New Friend:
Do not put of the fridge when it is not in use.... BY doing this sensitivity of thermostat is reduced... which result in incorrect switching of compressor
Posted on Jan 10, 2010
2 Suggested Answers
SOURCE:
  • 237 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
I have turned my fridge freezer off during 5 weeks. Since I'm back it's back on again, it cools and the freezer is freezing... but every day it rings and indicates that the freezer temperature (the re
Laurie a lot of people forget to leave the fridge and freezer door open slightly and the water from defrost hiding behind the rear wall of the freezer will keep the inside of freezer and fridge damp this will cause the freezer fan motor to rust and stop air circulation. Can you provide a model number? Thanks John Tripp Appliance 911
Contact me Here
Oct 22, 2014 | Refrigerators
Kenmore refrigerator freezer stopped freezing and cooling then several hours later started working again ?
Look at what time the defrost timer is set to. It may just be as simple as resetting the time or you may need to replace it .
Aug 04, 2014 | Refrigerators
i find it hard to believe the compressor is going out,if the fridge is staying cold,put a thermometor in the fridge and it should stay about 32 degrees,ideally around 40 is a good temp.if the freezer isnt staying below 32 degrees then it sure sounds like a thermostat problem.But i have heard of computers in these newer refridgerators but havent worked on any just yet.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Jan 07, 2007 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
28,643 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
