Question about Memorex Mega TravelDrive 4 GB USB Hard Drive
Mini memorex traveldrive 1GB
Hi,i have mini memorex travel drive 1 GB, the problem is that when i connect my flash drive, the autorun doesn't come up , also when i click on the icon to open it, it says that i need to format my drive,,, well,,,, i don't want to format my flash,,, cuz i have important files on it,,, how can i fix this problem?
    New Friend:
  • 22 Answers
To make any Drive Work formatting is a necessary step. If you don’t do it then it will never work.
Posted on Dec 19, 2017
SOURCE:
SOURCE: Memores 4G Mega Traveldrive doesn't read
Step one is try it on another computer. This will seperate issues....is it the drive or the USB port (hardware or software actully in both cases are possible.
Step two, if it works elsewhere, is to check under device manager, and reinstall the driver (if not embedded in the drive which most are)....both USB and the disk.
Step three is to download (again assuming it did not work) the disk diagnostics from Memorex (most drive manufacturers have a host of utilities and they may exist even for flash drives - they use them internal to their mfg operations as well). Check to see if it's good. It is possible that it just lost the embedded driver by the way in which case you need to put it back on the drive...haven't done that but assume it's possible and available.
Can give you more "stuff" to do but this will probably solve the problem....and I am guessing it died. If it did they are not expensive...and even cheaper if you really don't need 4 gb...few people do for personal and even work data.
Check at pricewatch.com (not a seller) for pricing. This site is used by GEEKS United for finding "stuff".
This gives you some options.....Tango
Posted on Jan 25, 2008
SOURCE: MEMOREX TRAVELDRIVE 1GB
Tohono, sorry about the other confusing mis-interpretations of your problem. I'll try to help you understand.
First of all there is little reason for a write protect error on your drive unless you have either inadvertently set an file attribute incorrectly or a protected system file has been stored on the drive, or in some cases a virus wll write protect itself when it installs to a drive.
A simple fix for all the issues assuming you have no data you wish to save, is to format the flash drive only. Please don't format your C: partition, only the USB flash drive, okay.
More detailed instructions are below
http://www.memorex.com/downloads/manuals/TravelDrive_Users_Guide.pdf
Posted on Feb 28, 2008
  • 252 Answers
SOURCE: I purchased a memorex 160GB traveldrive. I would
Things to ponder before deleting
Rather then deleting them right away, try moving the "day the files were uploaded" to another drive. Then try accessing the files on your memorex. Do the files and folders open properly? There not corrupt? Has the memorex hdd drive recreated the folder you just moved? etc...
Once your satisfied that yes there are two copies then you could safely remove one.
Posted on Nov 07, 2009
  • 1584 Answers
SOURCE: My Memorex 320 gb ultra travel drive is not
Sounds like the HDD is failing or failed. Try removing side cover to your PC (Switched off and unplugged from power supply) remove the CD cable / plug it into the ext HDD (Dismantled) boot into Windows.
If the PC cannot read the drive then it is damaged with loss of all files. If you can read it, I suggest you transfer backed up files to your PC before it fails completely.
Posted on Dec 30, 2009
Testimonial: "I think that's a good solution, thank you"
  • 211 Answers
SOURCE: I have just upgraded to a Windows 7 system. My
  1. break all ur partations and recreate them ... and then format the usb drive
Posted on Jan 10, 2010
I have forgotten password for encrypted memorex travel drive
you can send it off to one of those companies that specialise in data recovery if not all you can do is reformat :(
That is why they are secure ..... sorry :(
Jan 17, 2015 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
A PDF file on my data traveller has disappeared
This is due to some virus attack. Did you try any data recovery software till now? If not then go online there are so many good free data recovery software that can make your inaccessible pdf file accessible.
Feb 11, 2013 | Memorex Mini TravelDrive - USB flash drive...
I deleted all the memory in the flash drive, its a 2 gb, but it tells me that theres only 41mgb in it.
Try emptying you trash on the computer that you deleted the information on. Or recycling bin depending on the type of computer. When you "delete" the information from the flash drive, it does not permanently delete it until the "Trash" is emptied.
May 20, 2011 | Memorex Mini TravelDrive - USB flash drive...
Memorex Mini Travel Drive 8 GB USB 2.0 Flash Drive 2 drives are not recognized. Error message asks to reformat. Tried them at various computers including PC and Mac. Thanks. Yee
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Feb 18, 2011 | Memorex Mini TravelDrive - USB flash drive...
Trying to install in Mac G4 OS X 10.5.8 a no go
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Dec 30, 2010 | Memorex Mini TravelDrive - USB flash drive...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
When I plug in the travel drive, it does not show
The only way to recover the data will be to try a company that specifically deals with Drive Data Recovery. This will not be cheap, so you will have to decide on the value of the data you are trying to retrieve
Mar 06, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Can't store anything lately
Hi, did you format the flash drive? If you are using windows, right click on the drive and select "Format...". You can repeat the operation a few times. If it's working, try to add your resume again. How old is the drive? Good luck!
Apr 25, 2007 | Memory Upgrades 1 GB USB 2.0 Micro...
Memorex Mega TravelDrive 4 GB USB Hard Drive Logo
208 people viewed this question
Top Memorex Computers & Internet Experts
Vernon Taylor
Harrie
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
