Question about Sansui 19 in. LCD TV
I have a sansui tv and it wont turn on but is getting power what do i do
    Top Expert:
  • Sansui Master
  • 14,553 Answers
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.i have a sansui tv and it wont turn on but is gett - 6_6_2012_6_16_25_pm.jpg6_6_2012_6_16_48_pm.jpg
Posted on Jun 06, 2012
  • Mthetheleli Mpendu
    Mthetheleli Mpendu Apr 22, 2019
    Will open the set and check the Capacitors and report back. Thank you
    New Friend:
Fyi to anyone have the tv got unplugged and now its getting power but won't turn on. Leave it unplugged from the back for the night. It'll turn back on in the morning. Happened to me twice now.
Posted on Oct 13, 2014
SOURCE:
Sansui tv CTR wont turn on red light blinks
Open internal fuse or power supply failure
Jun 17, 2018 | Sansui Televison & Video
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Sansui sty1232 it block in standby mode
Try unplugging your TV from the electric socket for a few hours or preferably overnight. Hopefully your TV will then turn on
Oct 04, 2014 | Sansui Televison & Video
SansuiHDLCD4650 wont power up, red light indicating power to tv is lit.
The problem is in the Main board that also incorporates the T-con unit. Pull the main board out. Find IC 6201. Next to the two legs of IC6201, find Capacitor location C6212. Wick out C6212. Do not replace C6212. Your TV will come back to life! Thanks for asking, Matt of Martins TV Repair.
Aug 27, 2014 | Sansui HDLCD4650 LCD TV 46" - COWRIND...
Sansui tv
Check and replace its main power regulator board.
Apr 29, 2013 | Sansui Televison & Video
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
My sansui t.v wont turn on
1= you have problem with the main switch for open or faulty, test with VOM
2=check the power supply: a)filter b= coil c= trafo d=diode e=rectifier f= fuse or c.breaker repair or replace
3= HV rectifier for output horizontal +125 vdc +Flyback test
4= vertical output +80Vdc
5=12vdc for color
6= other circuite 12vdc.
see the block diagram
God bless you
Aug 03, 2012 | Sansui TVM1916 19" TV
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Sometimes
Apr 26, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Sansui 19 in. LCD TV Logo
7,292 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
