Question about KitchenAid Refrigerators
I can't get the front cap off the base grill on my freezer/refrigerator to replace the ice and water filter.
    President:
  • KitchenAid Master
  • 2,651 Answers
Youll need to remove the entire toe grill in order to remove the water filter,it should twist and pull rigth off, its ossible that on some models there are 1/4inch screws in the top corners holding the toe grill on
Posted on Nov 30, 2008
SOURCE:
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Apr 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Where the water filter whirlpool gold model no GS6SHEXMQ00 located? the last home owner lost the manual.
The base grille water filter cartridge is located below the freezer
compartment door. Depending on your model, you may have a
filter that is installed behind the base grille or a filter that
is installed through the base grille
This should be the right manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202188772.pdf
Mar 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I replace kitchenaid superba KSCS25FKSS00 water filter. When I try to turn counterclockwise with my hand it doesnt budge? I have never done it in 5 years
Here are some instructions for you.. it is important to press the ejection button and pull the filter straight out before turning counter clockwise..
1.Press the eject button to release the filter from the base grille. 2. Pull the filter straight out.
3.Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4.Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. 6.Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
I hope this information helps you with your filter. They suggest you replace the filter every 6 months. It could help the quality of your water and if you make a lot of ice..
Nov 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do I take out the water filter?
Found at Kitchen Aid website, Good luck
1.
Jun 30, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Can't locate the filter
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Filter is at the bottom of the fridge, in the grill, 6-8" from the left side.
Manual and parts list is available at http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gs5shaxtl01&siteCd=WHRCOM
Regards,
MrBoo
5. Remove the protective covers from the O-rings. Be sure the
O-rings are still in place after the covers are removed.
gaskets. Do not use paper towels, scouring pads, or other harsh
cleaning tools.
Nov 11, 2008 | Whirlpool Refrigerators
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
525 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
