Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Maytag neptune dryer belt off and loose
The other night i was getting clothes out of the dryer and turn in to go backwards to get the clothes out. Now it won't turn, it turns on and lightly hmmmmsss. I took off the top, felt the belt and then noticed ah hah! The belt was loose. Then went to the the back took off the lint tube saw the belt kinda hangin, i tried my dam nest to put the belt on and still too loose. Can someone help me? Or should i call someone, to make things more complicated, my wife has a new $1k Samsung being delivered. I would love to save that $1k. HELP!!
    Sergeant:
  • 197 Answers
The spring has come off the tensioner pulley or the spring may be attatched to the motor and the motor puts tension on the belt look inside for the spring id say its come off...
Posted on May 05, 2017
  • Maytag Master
  • 2,517 Answers
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
6ya staff
SOURCE:
Mike
  • 21 Answers
SOURCE: drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Posted on Jan 18, 2009
Anonymous
  • 65 Answers
SOURCE: Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Posted on Jan 27, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Coin Stuck In My Dryer
well, i can get into the machine, not aproblem.. is the coin perhaps trapped inside one or more of the innerr drum viens perhaps??? anyway, ifyou removet he2 screws securing the door, and the 2 screws opposite the hinge, the front "u" shaped front panel will tilt off fowards.. from there theres a few 5/16 screws holding the main top assy to the froma of machine, you can remove them and tilt the top back, giving you acess to the outer drum assembly( and you can removethe drum viens and retreive te hoffending "coins" in htat fasion.. hope this helps.. TURN OFF POWER TO UNIT<< LIVE WIRES!!!!!!!
Posted on Feb 12, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
Posted on May 28, 2009
Kiran Anto
  • 420 Answers
SOURCE: Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Posted on Sep 10, 2010
The vents have been cleared & I still have a buildup of moisture which won't let the clothes dry.
Most likely tour blower is slipping. It might be tossing out air but not enough. These dryers are notorius for having bad blower wheels.
To get into it kill the power and raise the top using a putty knife to release the top clips then get the front off and inspect the filter housing for lint. Their will be a big ball of lint. Grab the blower wheel and wiggle. If it is loose you will be able to tell.Hear is my crappy phone video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2013 | Amana DLE330RAW Electric Dryer
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Whirlpool dryer won't turn on can hear
The switch you speak of is a mechanical switch with electrical contacts. If the spring inside gets rusty, it doesn't turn properly....replace it!
Dec 26, 2012 | Whirlpool Dryers
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Nov 09, 2012 | Dryers
Dryer drum won't turn with clothes in it
nothing hasent fell out of the pockets has it? or it might be that there is to much cloths in the dryer
Apr 21, 2012 | Dryers
Clothes dryer wont turn
Check your belt. I actually heard my belt break, it was running at the time. We ordered the right belt, replaced it & it worked fine. You can find the instructions on how to replace it online. Now I have another problem, it won't start, I think it is the switch connected to the start button.
Mar 01, 2012 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
