Question about Kenneth Cole KC1232 Wrist Watch
Chronograph hand not resetting to 12 o'clock
My chronograph hand for this watch is resetting to the 1 minute to 12 position rather than 12 o'clock. My instruction book does not seem to cover this watch. The nearest instruction advises there is a corrector which can be pressed to solve this problem, however these is no corrector button. Service centre number is not recognised.
  • 1 more comment
  • stevepw Dec 07, 2008
    i have a wenger watch it works fine apart from the alarm and chronograph do not work, also the second hand moves at 5 second intervels can anyone please help
  • Secko Mar 09, 2009
    Hoping someone can help?
    My TW Steel watch's chronograph second hand slips which makes the watch lose time. If the chrono is in the correct position the time is correct, however every few days it slips a few seconds and when resetting it it returns to the same position.
    Has anyone ever experienced this and if so, any ideas what is causing it. Its happened with my last 2 watches.
    Thanks in advance
  • Dave Campbell Sep 10, 2013
    Second hand moving 5 second intervals likely means your battery is low.
For my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Posted on Jan 16, 2009
I have a Festina Chronograph and my second hand was sitting on 26" past. What I did was to pull the crown out all the way and then with the top button (the one that will activate the second hand under normal conditions) push it several times to get it back to the 12. You will see that every time you push it the second hand will move up by one hand. once your second hand is reset you can replace the crown. BUT.... my chronograph has a minute hand as well.... yep... you have to move your second hand like a million time to reset the minute hand. Good luck
Posted on Mar 17, 2009
  • L. Schultz Mar 10, 2013
    Worked only for red/second hand. Didn't work for other hands. My 'zero' is at 1 hour 55 minutes.with both hands wrong.
You can also use the start/stop button to ajust other chronograph hands while pulling the crown full and half way.
Posted on Mar 31, 2008
My seiko chronograph second hand, 1/20 sec and the minute hand all didn't line up. What I did was to pull the crown all the way out and press the top button to cycle thru the above 3 chronograph. You then press the bottom button to advance them. Say you press the top button and it the second hand that move. You then press the bottom button to advance to 12 o'clock. Repeat the sequence for the next chronograph hand.
Posted on May 04, 2012
    New Friend:
Great work mmcm006 ..this worked for me very well thanks
Posted on Dec 30, 2009
Hmm. Didn't work for me. (Wenger quartz)
Posted on Sep 27, 2008
    New Friend:
Worked for me on a Festina 2013 tdf.
wasn't a major problem but just didn't look right to me.
thanks.
Posted on May 20, 2015
    New Friend:
For longines .
If i pull the crown out to half position the top and bottom buttons move the chronograph hour and minute hands forward a notch.
If i pull out the crown fully the top and bottom buttons move the chronograph second and 1/10th of a second hands forward a notch .
holding the button in spins the hand round quickly .
once all hands pointing straight up push crown back in and bingo!! all is good and resets correctly to due north.
Posted on Aug 19, 2013
    New Friend:
  • 4 Answers
My Victorinox 241198 watch stopwatch does not reset to zero. It is currently at 1 hr and 55 minutes as it's zero. I can reset the (red) second hand to zero. How do I reset the stopwatch hour hand and minute hand to zero? Thanks.
Posted on Mar 10, 2013
    New Friend:
Victornox swiss army watch same complaints as above followed instructions every thing ok now thanks 700 dollar watch i got for 425 out the door love it all most cried when i seen the hands out of sink thanks again
Posted on Jul 03, 2012
I wish i could have researched this before i returned a beautiful Victorinox Chronograph that i bought for 70% off that had the same problem.
Now i know . . . THANKS!!!!!!
Posted on Feb 18, 2008
Life saver!!!
Don't know if you have this fixed or not yet, but this worked for me.
pull the crown all the way out. then press the chronograph start/stop button. the chronograph hand should tick forward every time (or every couple times) you press the button. I'm not sure if you go past 12 if you'll have to go all the way back around. but try not to.
anyways, when it's lined up, push the crown back in and then start the chronograph and let it go for at least a full minute. now when you press the chronograph reset button it should reset back to 12. hope this works!
Posted on Oct 22, 2007
SOURCE:
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Dec 17, 2009 | Police Watches
Reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 28, 2009 | Watches
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Kenneth Cole KC1232 Wrist Watch Logo
15,592 people viewed this question
Top Kenneth Cole Watches Experts
Arturs Kalnins
Arturs Kalnins
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
