Question about Cameras
Kodak easy share z1285 , what kind of batter camera uses
Wont turn on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
The Z1285 uses two standard AA batteries. You may use alkalines, lithiums, or rechargeable NiMHs.
Posted on Jul 07, 2012
SOURCE:
SOURCE: kodak easy share
the only thing that you can probably do i take it to somewhere where they can fix it. It is probably the only thing that will work. sorry. =/
Posted on Oct 01, 2008
MNfisherman
  • 11896 Answers
SOURCE: My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
Posted on May 30, 2009
  • 12 Answers
SOURCE: turn camera on and says memory full save to favorites .. no pictures in camera..using internal memory only
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
Posted on Jun 12, 2009
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
I broke the LCD screen on my Kodak easy share Z1285 how much will it cost to fix
Right now DiY for $28
KODAK EasyShare Z1285 LCD SCREEN DIGITAL CAMERA PART WITH REPLACEMENT...
For this particular camera it really is not too difficult. Of course, used ones are available for under $50 or you can get a really good upgrade for under $100 (all US $)
Apr 25, 2015 | Kodak Cameras
I cannot get my computer to recognize my kodak z1285. Also I cannot get a kodak easy share program that will download to my windows 7 What do I need to do?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 04, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Memory card formatting
Get a separate card reader and use it to download your pics to your computer. Then, format the card in the camera. 6153108.jpg
Jun 21, 2010 | Kodak EasyShare Z1085 Digital Camera
My camera will not turn off /on. lens is stuck in out position.changed batteries cleaned contacts, nothing!Been told these r known for this. this is my 3rd easy share
The problem is not sand, dirt, or grit. Take the batteries out of the camera and let it sit for an hour or so. Then put the batteries back in the camera. Always store and carry the camera without batteries. Insert the batteries just before you use the camera.
Nov 10, 2009 | Kodak EASYSHARE Z1285 Digital Camera
How do we move the photos to the memory card in the camera?
Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
Aug 06, 2009 | Kodak EasyShare Z1275 Digital Camera
Cannot download pictures from camera to computer
What system Are You Using? Im Using windows Seven And Vista, It Will Not Work . Just Use Sd card Reader Or Flash Usb Sd reader.
Jun 02, 2009 | Kodak EASYSHARE Z1285 Digital Camera
May 30, 2009 | Kodak EasyShare One Digital Camera
How to transfer pictures from Kodak EasyShare Z1285 to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
You may download the Z1285 User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00732/Z1275_Z1285_UG_GLB_en.pdf and the Z1285 Extended User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00731/Z1275_Z1285_XUG_GLB_en.pdf
Apr 07, 2009 | Cameras
Camera lens extended and blue light comes on. That is all. Cannot turn light off or retract lens Kodak Easy Share Z1285
The Lens Barrel gears are damaged ...... Get it changed by a repairman please
Oct 16, 2008 | Cameras
Clicked the wrong language it is in French I want English how do I change it
Go to settings (usually a toolbox icon), select language, choose english.
Jul 12, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
