Question about Kodak EASYSHARE Z1285 Digital Camera
Screen has static lines
Just started "acting" up with static lines....kind of like watching and of 8mm black and while film
  • 17,970 Answers
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Aug 07, 2012
6ya staff
SOURCE:
How many feet in 8mm
no feet in 8mm
roughly 8mm is 1/3 of an inch or 3/8 "
Oct 23, 2017 | Video Cameras
How to load a Sears du all 8 1973
Sears 8mm projector with 1950's & 60's films - YouTube
? 13:24
https://www.youtube.com/watch?v=7-IIS8ti7Ig
Jul 5, 2011 - Uploaded by drh4683
Vintage sears automatic projector. ... All 8mm and 16mm movie film, even going back to the 1920's and 30's ...
Sears Du-all Eight - Demo - YouTube? 0:37https://www.youtube.com/watch?v=WHbqCMKUGkoNov 13, 2007 - Uploaded by fierorcr86Buy This Now at www.mycurrentauctions.com I demo a Sears Du-all Eight super 8 ... How to load a Bell ...Sears Du-all 8 auto thread projector - YouTube
Jan 01, 2016 | Office Equipment & Supplies
Have split image when watching 8mm film video.
If my memory serves me correctly, you should have an adjustment knob somewhere... and it seems like it was marked "frame". Another caution: I assume you know that 8mm and Super 8mm are not interchangeable. However, some of the old projectors (like a Kodak I had) had a twist knob that would change the projector back and forth in order to play either film. Just some thoughts...
Dec 06, 2013 | Computers & Internet
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
SONY MP 120 8mm video cassette
Problem is dirty / clogged video head of v-8 player or camcorder what ever you are using for playback. Use good quality video head cleaning cassette for head cleaning.
Please check tapes on another camcorder as tapes seems OK.
Oct 22, 2008 | Sony 8mm Stantard Grade 120 Minute...
Kodak EASYSHARE Z1285 Digital Camera Logo
89 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
