Question about Motorola Cell Phones
Phone won't turn on
Shut phone off and will not turn back on. New battery and fully charged.
  • Anonymous Mar 28, 2014
    Phone shut down won't come back on was charged
  • Motorola Master
  • 14,641 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Aug 29, 2012
SOURCE:
RZRsucks
  • 91 Answers
SOURCE: motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
Posted on May 13, 2007
SOURCE: how do i resolve the error: use genuine battery. power off
I have an En-V 2, same thing happened.
What worked for me was dabbing a Q-tip in nail polish remove and just rubbing it along the 4 contacts on the battery as well as the 4 contacts inside the phone.
This is an old trick that use to work for the Nintendo game system cartridges when the game would **** out.
Give it a shot! I just saved $50 and a trip to the Verizon store!!!!!! (We know how that can be...hehehe)
GOOD LUCK!
MUZAQMAN
Posted on Oct 20, 2008
GrinningFool
  • 625 Answers
SOURCE: BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
Posted on Jul 05, 2009
longgee
  • 322 Answers
SOURCE: cell phone keeps turning off although is fully charged.
Sir, the problem may be in firmware. I suggest that you reformat it first. But after reformatting it and the problem is still there, the problem must be the hardware itself. To remedy that, you must replace each and every parts that you think has the problem like for instance the connector in the phone where you plug in the charger.
Posted on Jul 14, 2009
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
Posted on Jul 18, 2009
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My HTC mobile phone drains its battery too fast. I have to charge it every hour. This phone is brand new - only five days old.
turn the phone on and let it charge completelty. Then go and shut the phone off. Reboot the phone in CMV which is dos for phones. (you can do this bypushing a combination of buttons usually power, volume down and home check to see what yours is) go through the menus and look for Wipe Battery stats. IF YOU DO NOT SEE IT go back to the main menu and reboot phone. Wait for phone to fully charge again and shut it off. Now while it is off keep plugging the phone in till it says it is fully charged. Then unplug the phone wait ten-15 seconds and plug back in until it reads 100% when you plug your charger in
Apr 19, 2012 | HTC Cell Phones
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
P168 - shut down
try wiping off the connections n hold button down for a min.
Oct 17, 2008 | Dual Electronics CECT P168 Cellular Phone
Motorzor
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
168 people viewed this question
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
