Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse 32 inch screen goes blank
I have a three year old Westinghouse 32 inch flat screen lcd ready TV. It would run very well then go blank. Most of the time you could turn the TV off for a short period of time and it would come back on and work fine. Some times for days and days and some times for minutes. It went blank yesterday and now even turning on and off it won't respond.
  • 5 more comments
  • Anonymous Dec 28, 2008
    I have exactly the same problem with my three year old Westinghouse 32 inch flat screen TV. It worked fine and every once in a while it would go black. I could shut it off or unplug it and it would come back on and work fine. Then it started happening more frequently and finally it would not come back on at all. I would like to get it fixed, but, fear the cost to fix it would be more than buying a new TV; if I can find someone to fix it in the first place.
  • scooter101 Feb 13, 2009
    I can confirm this fix. Thanks for the link, too.
  • Anonymous Feb 21, 2009
    Only my TV is less then a year old. Sad tht a person can pay over a thousand dollars for something and not have it work less then a year later.
  •  PartStore
    PartStore Jan 18, 2013
    That link is now outdated. But you can find replacement parts for Westinghouse LTV32W! here:http://www.partstore.com/Model/Westingho...
  • Sam D Oct 02, 2013
    I replaced c162 but unfortunately the problem still happens here and there. Didn't see any other connections that are visibly damaged. Any other advice about other capacitors that might be the culprit, or how to test?
  • Danny nemal
    Danny nemal Jul 17, 2014
    search this 35V 680UF
  • Benny Kuang
    Benny Kuang Jul 22, 2014
    replaced c162. the power light show blue. but the screen is black. nothing on the screen. and I really don't know is that the power supply has a problem? should I spend 88 dollars to buy the new power supply?
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
  • 11 more comments
  • bwithg41 Mar 31, 2011
    i have the same problem with the westinghouse 32 inch. We should all write to them so They should be responsible and either help pay or fixed this problem. too many people had the same problem. We should tell them we will not ever purchase their product again! which I havent. I bought a Sharp and Samsung.
  • Tom Camp Aug 06, 2012
    Our ONE year old Westinghouse flat panel has the exact same problem. This should not happen in a TV this new. How to find a Westinghouse repair service?
  • s_ries74
    s_ries74 Feb 16, 2013
    bkdg....YOU are the man! Replaced C162 and works like a dream...a $3 fix...plus have 2 extra capacitors! Thanks a bunch!
    @bkdg100 I replaced c162 but unfortunately the problem still happens here and there. Didn't see any other connections that are visibly damaged. Any other advice about other capacitors that might be the culprit, or how to test?
  • Benny Kuang
    Benny Kuang Jul 17, 2014
    can you tell me where you buy the c162 capacitors. I search on ebay. but I really don't know which is fit? can you give me the link. please.
  • Danny nemal
    FYI , c162 is the location of the part not the value of the capacitor , you must read the value off the capacitor .
  • Benny Kuang
    I see. the capacitors show KY 35V 680UF M105C 5(7) 5D. size is 12.5x 20mm. I can find any seller they sell those capacitor. can you help me if you find the link. please. I don't want to buy a new TV.
  • Danny nemal
    search this: 35V 680UF
  • Benny Kuang
    alot in ebay. size can't found 12.5MMX20MM...do I have to find the one match the KY. what is KY Mean? just the Series or not?
  • Danny nemal
    you are over thinking it , 35v 680u or as close to it as you can find , ky series is just low impedence / long life , for use in power supplies . the height with is not critical , as long as the lead spacing will allow soldering to board . you can probably find similar caps inside of and old power supplies . dimension do not need to be exactly the same ..
  • Benny Kuang
    Benny Kuang Jul 18, 2014
    ok. I got it. thanks
  • Benny Kuang
  • Danny nemal
    Danny nemal Oct 06, 2014
    if you have reheated all solder joints and replaced cap , i would not spend any more effort or monet on a 32" tv .
I had the exact same problem and I fixed my Westinghouse 32 inch by replacing the power supply. You can purchase it at
http://www.partstore.com/Part/Westinghouse+Digital+Electroni/Westinghouse+Digital/4900211680/New.aspx?ModelMfgName=Westinghouse+Digital+Electroni&ModelBrandName=Westinghouse+Digital&ModelNumber=LTV32W1
I takes about 15 minutest to replace. Just take the back lower panel off and replace the power supply. Mine works like new now.
Posted on Jan 25, 2009
    Scholar:
  • 155 Answers
I had the same problem and changed the power supply all fixed. Power supply part number is DPS-210EP-2C and can be bought at http://www.moduslinkptstvboards.com/DPS-210EP-2C-P9987.aspx for around 60 dollars.
Posted on Dec 16, 2010
  • Tommy
    Tommy Jan 14, 2011
    ok im getting bad ratings cause there out of stock. sorry this isn't my fault. im just giving you directions to get the part. they also rebuild them.http://www.moduslinkptstvboards.com/DPS-...
  • Tommy
    Tommy Jan 14, 2011
    this company had 15 in stock 30 days ago. i didn't think so many people had this problem. i don't work for them just found the answer. please rate me fairly. and yes it take 10 minutes to change.
    Problem Solver:
  • 7 Answers
For those interested I repaired my powersupply by going over the connections with fresh solder. All of the main lugs of the transformer ect. Unfortunately now I have a problem with thick blue lines on the screen, but I think that means the LCD is bad.
Posted on Jul 30, 2009
  • Bob  Adam
    Bob Adam Mar 31, 2011
    I repaired this TV over two years ago, and the blue line turned out to be a lose connection on the pannel side. Two years later it still works perfectly.
    New Friend:
I replaced c162, first try is fail. second time it look like is ok. the display wake. but after 20 minutes, it screen shut again. that mean the problem is not on the Capacitor.
Posted on Jul 23, 2014
    New Friend:
I replaced power supply for same symptoms no luck.......
Posted on Feb 12, 2011
    New Friend:
I fixed this issue by replacing capacitor C162 on power supply...works great so far!
Posted on Feb 16, 2013
2 Suggested Answers
6ya staff
SOURCE:
Chi Chu
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
My Westinghouse Led flat screen TV freezes. TV is approximately 2 years old and not watched that often. From the internet, it seems the problem is quite common.
When the TV is OFF, the power supply, main board are still running 24/7 since it has to be able to receive the signals from the remote or from the switches on the TV, so it is never really off at all.
You are lucky it last 2 years, some of them TV I work on are less than 2 years old.
This an be the main board or the T-CON board problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Jun 25, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
May 21, 2010 | Westinghouse LTV-37w2 HDTV
The picture went black, but the tv still has audio
The back light inverter board may have gone out, or ir is not getting 24vdc from the power supply module, check those two places.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w1+
Jan 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Turn on tv screen shows for a second and goes blank.there is sound
three known fault possibilities:
1 inverters have no ac output too the CCFL lamps
2 power board has dc output shut down
3 timing control board has a switching short
Have your local repair center take care of this for you or if ts under warranty take it back....
Nov 10, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Blank screen when tv has been on for 10-20 minutes
Hi jilanfa00,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 20, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
What is wrong with My Westing house LCD TV
It appears like the power supply is dying on your TV. There are capacitors that become defective and will need to be replace to restore the TV functionality.
Let me know if you need further assistance, I service these power supplies.
Nov 24, 2008 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Blank screen no access
try setting up the tv using the default setting
make sure that the tv searches and installs al of the channels
Lou Margo
Allied electronics
Jul 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
11,480 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
