Question about Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter
Frigidaire water filter stuck
The manual says to remove the old filter by pushing in on the end and then pulling it straight out. But, when I push in on the end of the filter it does not release. I have tried many times. I can push the old filter in a little but it does not release when I let go. Any suggestions? I have the Frigidaire Gallery model and the filter is a PureSource Ultra.
  • 1 more comment
  • TM Eveland
    TM Eveland Mar 15, 2015
    This worked great! A magnetic nut driver would be helpful in not losing the nut and alo help in not burning your hand.
  • James
    James Apr 07, 2016
    That worked fine. A flange on the OEM filter was stopping it from coming out. Easy fix. Thanks
    Jz Cochrane AB
  • Tim Pieples Aug 29, 2019
    THANK YOU!!! Worked Great!!
    New Friend:
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Posted on Aug 25, 2013
  • 4 more comments
  • Jennifer Petersen
    Jennifer Petersen Jan 21, 2014
    We had to do this as well! But it worked!
  • dianalynnestogsdill
    dianalynnestogsdill Feb 01, 2017
    yayyyyyyyyyyyyyyy it worked!!!
  • Anonymous Mar 11, 2018
    YAY!! It worked!
  • Anonymous Aug 05, 2018
    This worked, the only other thing I had to do was push the bottom of the filter with the flat head screw driver and it popped out. also I used the flat head to separate the outer part from the filter housing before I found the one screw.
  • Millie Martinez
    Millie Martinez Jul 12, 2019
    No matter what I do filter does not come out , dont know what to do next
  • Pstoney Aug 13, 2019
    Open fridge remove everything on your top shelf, pop up on the light cover and remove it. Next you will see a Phillip screw holding the water filter cover in place, remove the screw and the cover should slide forward. The filter will be exposed, where the two filter heads connects stick your finger in between them and push up while pushing the filter in at the back and the filter should come right out!
    New Friend:
I found something that works. Use a flat screw driver to pop off the side plastic cover. This will expose a screw that holds the housing in place. Remove that and then there is an opening near the bottom that you can fit your finger into. Push up on the plastic connector that the water filter seats into while also pushing the water filter in. The filter comes right out. Do the same when putting in the new filter. It seems this connector sags a bit and pushing up on it helps.
Posted on Apr 10, 2017
  • 3 more comments
  • Eduardo Valentin
    Eduardo Valentin May 08, 2017
    Worked for me! Thanks a lot!!!
  • Tammy Brummett-Bauer
    Tammy Brummett-Bauer Jul 03, 2017
    Awesome. It worked. Thank you so, so much.
  • Dave Braeger
    Dave Braeger Mar 01, 2018
    This post saved me a lot of time! Thank you!!!
  • Tina Fuller
    Tina Fuller Aug 04, 2018
    Thanks and God bless you!!!!!!!!
  • Anonymous Feb 25, 2019
    YES! Totally worked. Sanity of a tired mom of twin toddlers totally saved.
    New Friend:
I had the same problem with the Waterfall filter from Amazon. It appears to be a basic design flaw that causes the filter to become stuck. There's a sawtooth part that slides onto the end of the filter. After taking my filter attachment apart to remove the filter it was clear that the sawtooth part had come loose and was catching on the housing preventing removal. I'd suggest avoiding this aftermarket filter else risk the headache.
Posted on May 03, 2017
    New Friend:
  • 39 Answers
You might have to force it out, using a thin object, have you checked for any clips holding it in place from the sides or underneath, some have snap clips which are hard to remove ,try prying it away from the end before pushing in on the end or try to remove from one corner,
Posted on Oct 02, 2012
  • Bobby Oct 02, 2012
    The last time I replaced the filter I was able to just tap on it and it released. This time it doesn't work. I may try to remove the plastic cover around the filter before I try to force anything. Right now I can't see anything to force - I can only see the very end of the filter sticking out of the plastic housing.
    New Friend:
I had a ULTRAWF "compatible" filter from amazon from the WaterFall Filter Company, and was unable to remove it, despite trying tips provided by other answers here.
I ended up removing the entire water filtration casing and taking apart the water filter system in order to get it out! Such a pain and definitely reviewed the product poorly on Amazon and won't be buying generic/off brand filters again for this fridge!
This site had a great video for my model of Frigidaire Profressional fridge (the only info I could find on safely removing the casing)
http://www.repairclinic.com/PartDetail/Filter-Holder/242009601/1513157#repairHelpVideoTabsAnchor
Once I took everything apart I simply had to nudge the filter's connector piece over a few millimeters and then it finally popped out of the filter holder.
Posted on Sep 14, 2016
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
Use a hair dryer on low and not too close on to filter and defrost it. It's more than likely frozen .
Posted on Aug 05, 2018
    New Friend:
Don't buy this kind from Amazon cheaper but hard to get off end up removing the 5 screws and getting it out. Thanks for advice
Posted on Jun 21, 2017
    New Friend:
Turn off the water supply into the fridge. Then let all the water out of the dispensing line. This should release enough pressure off the filter to get it to pop out. good luck
Posted on Dec 28, 2016
    New Friend:
I purchased a generic filter off Amazon named BEST refrigerator filter. Saved about 50% but when I tried removing it, it would not release. No matter what I tried it wouldn't disengage the latch when I pressed it in. My last effort worked. All I did was shut off the water supply behind the refrigerator, turn off the icemaker and drain the water from the dispenser. Once the pressure was reduced, the filter released and came out as it should. .....Lesson here was stick with the original filter.
Posted on Aug 08, 2016
    New Friend:
I been fooling with mine pure source 3 water filter for frigdare for three months trying not to break it. One day I turn the refrig temp button down to 5 for 20 mins and it pop right out.
Posted on Feb 14, 2015
    New Friend:
Had same issue on Fridigair ULTRAWF filter. You tube videos say just to put in - did nto work.
What did work was to hold the upper plastic housing against the fridge ceiling while pushing in. Apparently the tolerances are tight and if the plastic has dropped a little it will not come out
Posted on Jan 01, 2015
    New Friend:
I had the same problem. I found it awkward to push in to get something out. My husband had to do it. We found if you push with some force in and up it pops right out. Our problem is that it leaks constantly. We just moved in to a new home and the refrigerator is brand new and came with it. How is it possible that it leaks - a lot as a brand new refrigerator? It leaks pools and pools of water. Any idea on how to fix that?
Posted on Dec 23, 2012
3 Suggested Answers
SOURCE:
dcramer531
  • 1654 Answers
SOURCE: Water stopped flowing on my
If you by pass the filter does the water flow? I suspect your water valve may have gone bad. Have you tested that by any chance? Also make sure the filter is in correctly and no loose lines and is locked in tightly. I would do two things: make sure the water reservoir in the refrigerator (behind the bottom drawer) is not frozen and check if 120 VAC coming to the water valve solenoid while the water dispenser calls for water.
Here is a link to a page that describes how to test the water valves.
www.appliance411.com/faq/test-water-valve.shtml
Posted on Jun 25, 2011
espressonist
  • 1711 Answers
SOURCE: water is leaking inside of my refrigeartor. It is
The most possible reason is the spout drain tube and the drain tube are goggle with something including a peace of ice and the water produce from defrost it can pass thought spout or tube or it can ran freely and overflow in the fridge thus the dripping. The drain spout is no 25 and drain tube no 23 at the parts diagram of your fridge. So you can clean the spout and the tube using a long wire so the defrost water end on the drain pan over the compressor at the back of the fridge.
Posted on Sep 03, 2011
My Frigidaire ultrawf water filter will not stay installed after it clicks
Hi- not sure if it will help but I had issues getting it out. What I found is the plastic casing (fridge) needed a little twist/push. Play with it- hold the filter in and GENTLY push/pull/twist slightly the fridge housing.
Feb 02, 2015 | Frigidaire ULTRAWF Frigidaire PureSource...
How to change the water filter on kenmore refrigator 79570323310
On the 79570323310, you first need to lower or remove the top shelf from the refrigerator. This will allow the water filter cover to drop down out of the way. Press the button on the front of the cover to release the cover and drop it out of the way. Next pull the water filter down completely before you pull it towards yourself to remove it from the manifold hole in the water filter housing. You may want to put a cup under the water filter cover while it is down to collect the water that will come out with the filter. Next remove the new filter from the carton and remove the protective filter. With the tabs on the filter held horizontal, push the new filter into the manifold hole at the same angle as the old one came out. Then push the front of the filter up until it is flat at the top of the refrigerator. Finally push the water filter cover up until it latches closed.
Sears Parts Direct has the manuals for many of their appliances online, the manual for the 79570323310 is here: http://www.searspartsdirect.com/partsdirect/user-manuals/79570323310-kenmore-parts-REFRIGERATOR-manual .
I hope this helps.
Sep 03, 2014 | Kenmore Refrigerators
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Water filter won't release
Is it a push fit or screw in? Gently push up and twist anticlockwise if it's screw in. If it's push fit depress the inner part where the hose goes in and pull the hose at the same time. MAKE SURE the water tap is off before doing it and preferably unplug the fridge too.
May 01, 2012 | Frigidaire Refrigerators
How do i replace the water filter.
http://www.frigidaire.com/manuals Enter your model number
Manual link:
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241661500en.pdf
Actual precedure with pictures is on page 14 of the above link.
GENERIC Installation Instructions:
  1. Unscrew the filter cup and dump out the water
  2. Pull the old filter straight down and discard
  3. Place the new filter in the filter cup
  4. The end of the filter with the small o-ring should be up
  5. Screw the filter cup (with filter) up onto the housing
  6. The filter will self-align as the cup is tightened
  7. Reset your 'change filter' light (if your fridge has one)
Resetting your filter change indicator light:
  • Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds)
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Frigidaire Side By Side Refrigerator 26...
Installation of new water filter for model # ED2FH
This unit has the filter in the grill.
Removing and replacing a water filter - base grill location
. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Feb 12, 2011 | Whirlpool Refrigerators
Filter stuck in a Frigidaire FRS26R4A Side by Side Refrigerator. Tried and tried but pushing the release button does nothing. I've tried using a hefty screwdriver to pry it out while pushing the release...
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Frigidaire FRS26R4A Side by Side...
HOW DO I CHANGE THE WATER TUBING?
you need to go to lowes and get whats called a double ended quick connect,cut a little piece of tubing off and take it with you,push tubing in on both ends,now run your door water dispenser till the water is clear,with icemaker on make a couple of tray s of ice,throw away,remove quick connect by pulling round tab in and pull tube out,install filter and your good to go,hope this helps,thanks-mike
Jun 01, 2008 | Frigidaire FRS26KW3AW Side by Side...
Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Logo
25,020 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
