Question about Apple iPad (16 GB) WiFi Tablet PC
My ipad wont charge , icon shows it's charging but it not ?
Usb wire started to fray so bought to new usb wires and it wont charge , even borrowed a friends and it still wouldn't charge ? any idea why
    Guru:
  • 160 Answers
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Posted on Nov 02, 2012
SOURCE:
SOURCE: charge the ipad in Car
The ipad need high power usb port.
The normal iphone/ipod adapters will not work.
buy an dc/ac outlet and a second charging brick from apple!
Posted on Apr 12, 2010
  • 846 Answers
SOURCE: Can't charge the ipad from the USB charger
The USB port of a Computer may not provided the same amount of charging current as your wall charger. Do you have other power hungry devices connected to the computer? It may help to get a USB hub with external powersupply. If all else fails the iPad doesn't charge on any USB port, you may actually have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Jun 02, 2010
  • 502 Answers
SOURCE: My iPad will not turn
If it refuses to charge when connected to any computer, charger using any charging cord and you have done a hard reset you have a broken logic board or dock connector and should take it to the apple store. If they won't help you, you can try to replace the part yourself, it is available on any auction website. There is an iPad Repair service that can fix it for you, but if you're a little tech savy you should use an iPad repair guide that teaches you how to do the repair yourself.
Posted on Apr 11, 2011
  • 846 Answers
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
  • 53 Answers
SOURCE: iPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Posted on Feb 23, 2012
IPad will not charge even though battery and charge port both replaced.
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Nov 30, 2015 | Apple iPad 64 GB 3G Tablet PC
Tip
How to get Apple Ipad to charge from usb
on Feb 17, 2011 | Tablets & eReaders
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
My Ipad is charging very slowly and is not rocognized on Itunes when I plug it in to my computer. Could the "charging port" be damaged?
No.That is an issue all Ipads have not showing the charge because of low voltage from usb.Download asus aicharger by search on web and install then restart computer.Plug in usb from Ipad and will show charging..
Jan 25, 2011 | Apple iPad 32 GB WiFi Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
1,769 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
