Question about Video Game Consoles & Games
My 3ds won't turn on and it fully charged
Every since i charged it last it will not turn on you will see the light for 5 seconds then turn off but it is fully charged
    New Friend:
  • 5 Answers
You probably have a blown fuse. Here is a video showing how to fix it. If you are not confortable doing the repair send it to nintendo to fix it.
Posted on Oct 18, 2012
SOURCE:
3DS charging issues
The charge port has probably been worn out. If you have the electrical skills, you may be able to replace it.
Jun 18, 2013 | Video Game Consoles & Games
3 ds will not turn on
1. Make sure the battery pack is charged: Connect the 3DS to your charge cable or place it on the cradle. Make sure that the battery is charging. (Indicated by the orange light on the front. Even if the battery is fully charged, this light will come on briefly and then turn off.)
2. Press and power button and make sure the blue power light turns on. If this light turns on but you do not get any picture or sound, you may want to consider sending your system in for repair.
3. Make sure any DS or 3DS game card inserted is properly inserted into the game card slot. The game card should be inserted with the label facing out and then pushed into the slot until it clicks into place.
4. Check that the battery has been inserted properly. Unscrew the back panel of the unit, remove the battery and reinsert it, making sure that the contacts on the battery match up with the contacts on the system. The battery should be inserted so that the "positive" (+) and "negative" (-) icons on the battery are facing up. CAUTION: There was a known glitch in the system at launch that prevented players from tagging other systems that they've already tagged if the battery is removed for a certain period of time.
If none of the above works, you may need to send the system in for repair. Check Nintendo's support site for repair information.
Read more: http://wiki.answers.com/Q/How_do_you_troubleshoot_a_3DS_that_won't_turn_on#ixzz274f71pEg
Sep 21, 2012 | Nintendo 3ds Handheld Game Console- Cosmo...
Phone won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | Motorola Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Battery is fully charged, lights flash, securty lights won't stop flashing but bike won't turn on?
Hi Maritza, for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 11, 2012 | 2009 Harley Davidson FXDC Dyna Super Glide...
My Sony Vaio PCG-61611L won't power on, the battery is fully charged and AC adapter is working (green light goes on). Please help!
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 15, 2012 | Sony Computers & Internet
How do i do a system update for my 3ds?
To update, first make sure you're connected to the internet and go into System Settings (this should be available on the main screen once you first turn the 3DS on, it's the one with an icon that looks like a wrench). From there, go to Other Settings, then System Update. After agreeing to their terms, you'll be downloading the latest update - just make sure you have this plugged into the electric or are fully charged before you try!
Aug 26, 2011 | Nintendo Video Game Consoles & Games
Video Game Consoles & Games Logo
1,768 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
