Question about Hoover Washing Machines
Hoover WMH168D error code E08
What is error code E08
    New Friend:
  • 3 Answers
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
Posted on Sep 18, 2013
  • GammyKnee Aug 30, 2017
    Big thank you for this. Washing machine (Hoover OPH714DF with E08) working again for under a tenner. Followed your diagnostics on the tacho and it played out exactly like your fix: worn brushes.
    Top Expert:
  • Hoover Master
  • 9,472 Answers
E08 = Tacho fault
The tacho coil is on the motor and is fitted at the opposite end of the drive belt where the carbon brushes are. This error says something is wrong regarding the tacho coil but it doesn't specify exactly what. Possibilities are varied so unless you know what you are doing, and unless you can see something obvious like the coil has come away from the motor or the motor or drum has seized up it is probably better to call in a professional.
Resistance readings for tacho coils are usually quite high, so if you don't have a sensitive enough meter it could appear to be open circuit when in fact it's reading over 150 Ohms or more and may be ok.
In conjunction with a magnet fitted on the end of the armature shaft each time the motor does a revolution it can be counted by the software or pcb through the tacho coil. This information is used to judge and control the speed of the motor at all times.
If the coil is open circuit the washing machine would lose al control of the motor and in the past the motor would often spin uncontrollable causing damage to the washing machine. These days if an open circuit or missing tacho coil (they can fall off the motor) is detected the machine will stop working and report an error code.
Posted on Oct 18, 2012
3 Suggested Answers
SOURCE:
  • 1768 Answers
SOURCE: Hoover washing machine - door won't open and drum
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Posted on Mar 13, 2010
Testimonial: "Thanks for your help, it's working fine now :-) "
StuartB
  • 807 Answers
SOURCE: why does my hoover wmh168d bang so loudly
It could be a problem with the balance of the machine. Make sure it's level on the floor. Could also be a problem with the suspension that supports the drum. Usually there are springs at the bottom of the drum and a lump of concrete at the top to keep the machine stable. They could be loose or broken. Also, when you open the door just have a look at the drum, see if you can lift it around the entrance, if it feels easy to move up and down without moving the rest of the machine then the drum bearings could be broken / loose.You really need an engineer to take a look, unless you know someone like a friend who could look for you.
Posted on Feb 20, 2012
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
What is error code 7 on hoover wmh168d?
Louise, E07 means "Motor fault. check motor, tacho and associated wiring, check drum has not jammed" Presuming you can spin the drum by hand, I'd put my money on the carbon brushes in the motor being worn out and needing replacement
Sep 23, 2015 | Hoover Washing Machines
E08 on my dryer
Search online for "error code E08 + your make & model"
Aug 23, 2015 | Hoover Dryers
Hover OPD 714 D 7kg . What does E08 mean
http://service.hoover.co.uk/manuals/OPH714D_1.pdf
user manual
http://www.whitegoodshelp.co.uk/hoover-error-8/
here is a description of the common error your machine has
and how too solve it
hope it helps you...
Mar 04, 2015 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
12,026 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
