Question about Hoover Nextra HNF 3157 Front Load Washer
Not spinning in high speed
Hi my washing machine seems to be washing ok but when it comes to a spin it spins a little bit but soon as it goes into a high speed spin it drops out of sipn then trys again over and over please help me
  • Kavisha Kumarasingha
    Kavisha Kumarasingha Jan 20, 2014
    ITS HAPPENING WHEN ITS COME UNBALANCE,,
    New Friend:
The description matches the problem I am having. When it drops out of high speed spin, it incredible rapidly slows down from high speed to normal speed sub second, fast enough to make the drive belt squeak. At the same time all the lights at the front go off. The program then steps backwards and the machine keeps repeating the spin cycle.
Posted on Feb 11, 2010
  • 883 Answers
Possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Posted on Jun 03, 2007
6ya staff
SOURCE:
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Sep 18, 2017 | Hoover Washing Machines
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
I have a ge washing machine that on the spin cycle kicks on and off
Don't know the model but if it is a two speed model and is clicking off and on when set for high speed spin but seems to start up and spin OK in slow speed spin, you have a bad motor
Dec 19, 2008 | Washing Machines
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Hoover Nextra HNF 3157 Front Load Washer Logo
524 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
