Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung 32 inch remote control problem
Model LE31R51B 32 INCH LCD TV
i HAVE A PROBLEM WHERE THE REMOTE DOEAS NOT OPERATE ANY FUNCTION EXCEPT THE VOLUME. THE RED LED ON THE MAIN POWER SITCH FLASHES WHEN I SEND A COMMAND BUT NOTHING HAPPENS
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Posted on Jun 21, 2009
SOURCE:
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
I have a samsung LCD 32 inch and have remote problems, I can change channels ok however when I try access the TV guide the remote fails to load the page. The TV option on the remote lights up as if its not...
Hi anthonymagee,
I have had similar problems in the past, the remote was faulty (a common problem). If you have recently bought the TV phone Samsung for a free replacement i.e. (08707267864 in the UK).
Alternatively (worth a try)
1. Remove the batteries from the remote.
2. Press and hold the remote's power button for 30 seconds, then release.
3. Insert the batteries.
Hope it helps, Dale.
Dec 20, 2008 | Samsung TV Remote Control
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Dec 13, 2008 | Samsung LN32A330 32 in. LCD TV
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
351 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
