Question about LG WM2688H Front Load Washer
Is there a reset button on the LG front load washer
  • 3 Answers
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Posted on Mar 01, 2009
  • Terry Ross
    Terry Ross Feb 05, 2014
    yes you un plug the washer then hold thepower button for about 10-15 sec and it will reboot the washer
  • Peggy Campbell
    Peggy Campbell Feb 14, 2014
    This one didn't work for me. Got any more ideas?
    New Friend:
I have finaly learned how to work my washer again:-]
Posted on Jul 22, 2015
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
If your machine is turning on by itself then off again randomly then the reset is the thing to try first un plug the machine from the power supply then hold the power button on for 10 -15 sec then release and plug the machine back in it should not power up until you press the power button again
Posted on Feb 05, 2014
  • Chris Minucci
    Chris Minucci Apr 27, 2015
    un plug itm spin the drum clock wise, it resets the computer, all the lights flashed on then off with it unplugged, must have a battery back up internally or ther drum acts likes a generator when it spins, long story short uplug it spin there drum then plug it back it, it works great, my problem was the machine tired off and wouldn't turn back on
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
Anonymous
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
I have letters le flashing on my lg front loading washer it won't spin
The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Sep 25, 2010 | LG WM2277HBW XL Front Load Stackable...
LG front load washer says LE on the desplay
LE is overloaded motor- most likely speed/direction sensor.
Call 1-877-714-7486 for LG reset proceedure and verification test.
Sensor is inboard of motor removed from the back.
Hope this helps
Jul 02, 2009 | LG WM1814CW Front Load Washer
LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Oct 28, 2008 | LG WM2277H Front Load Washer
Cant rurn on my my washing machine
Have you tried a simple reset, by unplugging, waiting several minutes and then replugging it in? Is it plugged into a gfi outlet? is the little red button pushed in? It should be. It hasn't flipped a breaker off has it?
Aug 15, 2008 | LG WM-1485FHD Front Load Washer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
LG WM2688H Front Load Washer Logo
6,324 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
