Question about Konica Minolta Bizhub C360 Copier/Printer/Scanner
Error code 530
Scanning to email error 530
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Roadrunner Email Error 530 arose when Roadrunner Email users are unable to send email to any email address. This issue causes to the email addresses which are not registered by SMTP (Simple Mail Transfer Protocol). Sometimes users have to use the different server to send emails to the recipients.
Causes Of Roadrunner Email Error 530
Following are the reasons into which users face such type of error while using their Roadrunner:
  • Roadrunner does not permit emails from any other outside network
  • Use of different servers during sending emails to any other email address Roadrunner email service may not be able to run on every operating
Steps to fix Roadrunner Email Error 530
Click the Tool Section: Roadrunner email users should select the Tools menu which is located in the header of the window screen and then choose the Accounts icon.
Choose Mail Tab: Click on "Mail" tab which will be visible in the Internet Accounts Window menu and then choose the Don host email account button.
Tap Properties Icon: Click the Properties icon to open the Properties Dialogue box. It helps you to access your email account.
If you are not able to rectify Roadrunner email error code 530 with the help of these steps, you can dial our toll-free Roadrunner Email Support Number 1-800-993-5590. This number is available 24/7 for you.
Posted on Jul 12, 2019
SOURCE:
When I scan a document in the computer and want to email it to some-one I have this message "530 authentification required...
FixYa might think after someone has answered or solved the problem you might disappear.
How much $ are the charges to register ?.
Error 530 occur when you use a laptop on a network that is not your own. You can receive emails, but you cannot send them. Some wireless Internet service providers block Port 25 because they think you are a spammer sending malicious emails. Here are a few tips to get around Error 530.
Open Microsoft Outlook. In the "Tools" menu, navigate to "Accounts," "Server" and then "Advanced." Observe the SMTP port setting. If it says "25," change it to "587." Press "Apply," and then click "OK." Exit Outlook, restart your computer and reopen Outlook. Send an email to ensure that your email goes through the system. Attempt an alternative solution. Inside Outlook, select the "Tools" menu, click "Account Settings" and "More Settings." Check the "My outgoing server (SMTP) requires authentication" option. Exit Outlook, restart your computer and reopen Outlook. Send an email to see if your email goes through the system. Consider temporarily using web-based email instead of Outlook. For example, if you have a Yahoo! email address and normally access your email through Outlook, open a web browser and type "http://mail.yahoo.com" instead. Check with your specific email provider to see if webmail is available and what address to use. Hope this helps.
Dec 09, 2012 | Microsoft Outlook Express
A message error said a message i tried to send using an email address i have used for several years could not be sent due to server error 530. recently windows 7 was installed in my computer. what do i do...
A 530 error indicates that the outgoing email server can not figure out who you are, therefore it is not allowing you to send email.
You did not specify what email program you are using.
You need to go to the email configuration and make sure...
a) you email address is correctly entered. Look for silly spelling mistakes.
b) Also check the entry in the configuration for "Reply-to". It should also have your email address in it. Some servers will reject mails if this is blank or incorrect.
Apr 06, 2011 | Computers & Internet
Why can't I receive e-mail through Outlook? I get error code 530 it also says password invalid
The error code that your'e getting, which is 530, means that the password for the account that is set-up on your outlook is wrong. You might need to change the password of your email account in outlook. For the instructions on how to change the password, you can search it on the internet depending on the version of outlook that you're using or you can contact the email provider that you're using for them to assist you in changing your password in outlook.
hope this helps.. regards
Mar 24, 2011 | Acer Aspire 3680 Laptop
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was 'fkb@ameritech.net'. Subject '', Account: 'pop.attyahoo.com', Server:...
One problem is that the incoming (POP) mail server shown in the error message appears to be incorrect. The server address should be "pop.att.yahoo.com" (with a period between "att" and "yahoo"). The incorrect mail server address may interfere with authentication of the sender's email address, which is needed before the outgoing message is sent.
The "530 authentication" message indicates your outgoing (SMTP) server likely requires "server authentication". Also, the "Port 25" message indicates your email program is currently trying to send via Port 25, with no SSL; but Ameritech/Yahoo accounts appears to use Port 465 with SSL enabled.
See more on sever settings for "ameritech.net" users:
http://www.dslreports.com/faq/5535
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61941/~/i886---at%26t,-bellsouth,-sbcglobal,-ameritech-email-settings
I would suggest you check the settings for your Ameritech email account in your email program. You may need to correct several settings. The steps to access account settings are somewhat different for various email programs (Outlook, Windows Live Mail, Thunderbird, etc.). You should be able to find guidance in the "help" section of your email program.
Feb 05, 2011 | Outdoor Concepts OCI AD20 27 Stainless...
Sent e-mail error 530 error number ox800ccc78 port 25.and ox800ccc92 and ox800ccc90 at port 110
If using Outlook, the problem should get solved by going to your email account settings (Tools > Account Settings > More Settings), and checking the "My outgoing server (SMTP) requires authentication" option.
Then try to send the email.
Hope this helps.
Dec 12, 2008 | Computers & Internet
Sending e-mail
Well, did you try going to the help website given? That would be extremely wise. ^-^ I went and it seems to answer many questions.
Jun 10, 2008 | Microsoft Office Outlook 2003 for PC
I can not send emails. I am being told that I need 530 authentication is required. What is that.
error 530 has something to do with incorrect logon details. pleas double-check your outlook configuration. like the smtp server, outgoing server, or incoming server. re-enter your account details like username and password then try again.
Jun 05, 2008 | Computers & Internet
Konica Minolta Bizhub C360 Copier/Printer/Scanner Logo
924 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
