Question about Radio Communications
Sandstrom manual shfjmc11
Cant tune in radio
    New Friend:
If you look at the rear of the ipod cover you will see a black plastic flap that is also the ipod lever when it is open, protruding into the door. you need to insert a thin knife blade and push this flap back so it clicks into position flush with its housing. this will take the lock off.
Posted on Feb 14, 2014
I am getting 'door key lock' error on sandstrom shfjmc11 system. any ideas greatly welcome. Thanks.
Posted on Sep 11, 2013
  • jayne cleworth
    jayne cleworth Oct 12, 2013
    me too, have you found a solution?
    New Friend:
Hi how do i turn off the timer on my sandstrom shfjcm11
Posted on Mar 20, 2018
SOURCE:
I need a manual for Sandstrom SPLDAB17
Try Googling (Sandstrom)(SPLDAB17)(manual) without parens.
Feb 22, 2018 | Televison & Video
How do i put store a station in the presets on my sandstrom sdabxrw13 radio
Tune to the station you want - press Mode/Menu.
Rotate Tune/Select one step to the right to display Store and press Tune/Select.
Jan 05, 2018 | The Audio Players & Recorders
How do I download a Manual for sandstorm shfjmc11
Try Googling (sandstorm)(shfjmc11)(manual) without parens.
Jul 19, 2017 | Office Equipment & Supplies
How do I get a user manual for Sandstrom S10DPF13 9.7" digital frame
Try to download from the following site,see if it helps
https://www.manualslib.com/manual/749223/Sandstrom-S08dpf10.html
Mar 02, 2017 | Photography
I have a Sandstrom DAB micro Hi Fi system SHFJMC11 and can not open the door (says door key locked)
just inside the ipod cover you will see a thin black plastic flap that is also the ipod lever, protruding into the door. you need to insert a small thin knife and push this flap back so it clicks flush into it's position. this takes the lock off and you will be able to open the door.
Dec 26, 2013 | Cars & Trucks
How do I pre set radio stations on sandstrom s9dabi12
That's right. Sandstrom (Dixon's) will email you the manual for their DAB/FM/iPod dock if you ask.
http://www.sandstromstyle.com/contact
Oct 19, 2013 | Audio Players & Recorders
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
Dec 12, 2009 | OEM Systems Car Audio & Video
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Cant tune radio in on system as do not have manual
try googling the manufactorie compony most of the have manuals online that you can download
Mar 22, 2009 | Audio Players & Recorders
Radio Communications Logo
844 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
