Question about Coby kyros Tablets & eReaders
How do I factory reset my Coby Kyros 1125?
I need to do a factory reset on my daughter's Coby Kyros 1125 because she has forgotten her password. The reset that is used for the MID7015 will not work for the 1125. If I push the power button and the volume button at the same time, I do get a different screen but I'm unsure how to proceed. Any help would be greatly appreciated!!!!
  • Coby Master
  • 3,015 Answers
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
Posted on Oct 17, 2017
6ya staff
SOURCE:
Vlad Kuznetsov
  • 12 Answers
SOURCE: where can i get android 2.1 for my coby kyros
From what I've read, the tablet comes with Android 2.1 already installed on it. Try going to Settings->>About Tablet and making sure that Android version is 2.1.
Posted on Feb 28, 2011
Fred Flintstone
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
jmernst
Janine Ernst
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
uoftenwinny
  • 274 Answers
SOURCE: coby kyros factory data reset
It's better to contact the supplier for tech help, because I didn't have this tablet before.
Android 4.0 Tablet PC
Posted on Feb 07, 2012
Edward Wolf
SOURCE: will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Posted on Mar 31, 2012
I can't remember my password to get in my tablet. How do I reset it?
Forgotten Password ' Android Tablet Forum
www.androidtablets.net > ... > Sony Tablets > Sony Tablet S
Jan 28, 2012 - 11 posts - ‎9 authors
My little brother set a password on my tablet and then forgot it .... is there anyone out... there is no 'forgotten password' and i have tried resetting it so i have to a standstill... alright thanks.... how do i do a complete restore ? How Do I "Factory Reset" My Tablet?
Oct 17, 2013
Forgotten password
Jan 22, 2012
Forgot Unlock Pattern for Coby Kyros
Mar 11, 2011
More results from www.androidtablets.net
Jan 29, 2016 | Tablets & eReaders
Kyros. How can I remove password?
factory reset, press the helpful button and check link video below
Factory reset on Kyros MID 7012 without using Settings
Jan 16, 2016 | Coby Tablets & eReaders
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
Jul 30, 2015 | Coby kyros Tablets & eReaders
I forgot my password and now i cant get on my coby kyros.What do i do????
I HAVE FORGOTTEN MY PASSWORD TO GET INTO MY 7INCH COBY KYROS TABLET.NOW I CANT GET IN IT.I HAVE TRIED RESETTING IT AND EVERYTHING.ANY SUGGESTIONS
Sep 02, 2013 | Tablets & eReaders
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
I have forgotten my wireless network password to connect to the internet. How do I recover it or re-set it (on my Coby Kyros Tablet)
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
May 30, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
94 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
