Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sound I have no sound from my tv speakers since unplugging the power source for the TV and theatre system (Sony DAV-Is10). It was unplugged for one week and on return I have good picture quality but no sound either through the TV or home theatre system. Oddly if I play a DVD or Netflix program through separate box sound is fine. I have checked audio settings and all cables. I have also tried to "reboot" the TV and select the Theatre settiing on the remote. Help please
6ya staff
SOURCE:
Anonymous
SOURCE: Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Posted on Oct 18, 2007
Anonymous
  • 13 Answers
SOURCE: connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Posted on Feb 10, 2008
Anonymous
SOURCE: kdl-40s3000 hdmi settings
I'm I agree with Joe. I have an Sony KDL-40X2000 and I saw it, very fragile and bad hdmi hole for cables (usually rigids). Even more one of my HDMI have same problem as Junh and I guessed it dead
Posted on Jul 10, 2008
Brandon M.
  • 34 Answers
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 06, 2008
Anonymous
  • 7 Answers
SOURCE: How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Posted on Jan 07, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Sound Problem
I'm unclear about the comment"If I play a DVD or net fix through separate box" What do you mean by separate box? Please reply.Be specific about what inputs on the tv and what settings you have check in menu as far a sound id concerned.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi all, I hope someone out there can help me. Recently bought a new Samsung 46" LCD, I also have a Samsung BluRay player and HD Recorder in one, also have a PS3 and finally the Sony DAV-IS10. ...
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
Sep 24, 2011 | Sony DAV-IS10 System
Hi I have the Sony DAV-HDX285 home theatre system and I'm trying to get it to work with my Vizio 47" HD tv. I go thru the speaker setup with the dvd supplied and all speakers are working tthu the home...
I assume you mean the TV sound only comes out of the TV. THAT would involve internal audio controls at the TV.
Why don't you just connect the TV-related audio directly from each source to the DAV instead of through the TV, which adds NOTHING to the sound quality and may even degrade or limit it.
Aug 17, 2010 | Sony Bravia DAVHDX285 Theater System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
Connection/sound issues!
Feb 10, 2008 | Sony DAV-IS10 System
Sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
Jan 17, 2008 | Sony DAV-IS10 System
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
