Question about Maytag Atlantis MAV6000 Top Load Washer
Capacity maytag mav6000aww - Maytag Atlantis MAV6000 Top Load Washer
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
Maytag MAV6000AWW does not come on. Electrical
It's probably not the motor.
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 04, 2009 | Dryers
What is a fair price for a maytag mav6000aww, we think 5 years old?
i would not pay more than 150.00
\ and only after i hooked up a hose and watched it work
these machines after five years have a way of loosing spin
and nailing it down is hard for a vet repair man
somtimes they just end up through parts at it
i would want to see it drain
and hear it spin
if they wont let you test it walk away
there apre plenty of good machines available on craigslist
Oct 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Slow spin cycle, clothes still very damp
ahhhh but it is
needs a new belt
it is strectched
Oct 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Rope wrapped around agitator. Maytag model MAV6000AWW. Would like to remove agitator. I have unwrapped rope as far as it will go.
Hi bmace77
if you pop off the top of the agitator where you put the softner and look in side,you will see a bolt its a 1/2 inch un do that and it will come off.
brent
Sep 29, 2008 | Maytag Washing Machines
Quit Working
it would be the switch get a knife and swip at both ends off ware the top lid section meets front side[join at front]this will allow top section to lift up switch may be broken or to short to turn on if to stort drill hole & pot screw in to adjust lenght of swich leaver
Dec 12, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
732 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
