Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
KDL-32M4000 - squiggly broken (dotted) line on top of non HD chls
Hi. A friend of mine as well as me just bought the same TV: a KDL-32M4000. When in channels that are NOT broadcast in HD, or when viewing channels not in the HD range of channels, we both get a squiggly line on the top of the screen. Above the picture. It is a broken (or dotted white) line that flicks and distracts from the picture. The only way to remove it is to change the screen setting to zoom wide and this is not something that I want to do.
Is this normal?
Thanks
Fred
  • fsileo Apr 13, 2009
    you have to change the cable from HDMI to component
6ya staff
SOURCE:
guacamole
SOURCE: Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Posted on Jan 06, 2008
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
Anonymous
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
dave1645
Dave Naylor
  • 834 Answers
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
Posted on Sep 17, 2009
ncqowien
SOURCE: Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Posted on Apr 06, 2010
How to set Sony Bravia tv for sound only
Do you mean you want the TV to display no picture yet be playing the sound from a TV show? If so, sorry, there is no "audio only" setting for this model.
Aug 22, 2014 | Sony BRAVIA KDL-32M4000 32" HDTV LCD TV
Where I can to buy an new eeprom to one LCD sony KDL-32M4000 ? I hope you can help me !! thanks
You can try to obtain the EEPROM from a local parts source or you can search the internet for a source of the specific type
Mar 07, 2013 | Televison & Video
My sony tv model, kdl-32m4000. doesnt get power on. tunrned off from runing condition the other day we tried to turn back on, didnt work.
Unplug tv from wall socket for minute, replug back in and turn it On.
Problem still not solved? let me know do you get power indicator light on tv? is it solid or blinking?
Jul 05, 2011 | Sony KDL-32M4000 LCD TV
No power
Hi, any strange noises clicking or buzzin? Have you replaced the lamp, if its been2-4 yrs without replacing it it might be time to do so, If you have replaced it check if power supply its workin properly.
Apr 19, 2011 | Sony KDL-32M4000 LCD TV
My Sony TV KDL-32M4000 won't turn on. No lights sound or anything. I opened up the back and it is clean with no odors. Are there any fuses I can check or power supply I can replace? Suggestions?
Yes there is soldered in fuse in the power supply board as shown here:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj147409911.jpg
Boards for your tv:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Sony+KDL-32M4000+&stock=all
You need to check the DC outputs of the power supply and inspect the caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 20, 2011 | Sony KDL-32M4000 LCD TV
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
Blue haze/blue dots on hd tv
You likely have a bad optical block. Sony was supplying the optical block as a warranty repair until June of this year, but that warranty has expired.
Oct 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
