Question about Samsung LN46D630 LCD TV
Tv turns off automatically; the more I turn it on, the more quickly it turns off
I have a samsung LN46D630. When I turn it on, it will stay one for a few minutes, then shut itself off (the red light turns off, and the screen is black; I've looked at it in a darkened room and there is no light coming from the screen). I can turn it back on but, when I do, it stays on for a much shorter period of time, say 1 minute, before turning itself off again. If I turn it on again, it will stay on for just a few seconds, then turn itself off. I've noticed that if I leave it off for a while (for example, overnight), then when I turn it on the next day, it will again stay on for 5-10 minutes before turning off. Then the whole cycle starts again (=turn it back on, stays on a minute or so; turn it back on, stays on a few seconds). I have no knowledge of the inner workings of a TV but this seems like a heating issue to me (bad heat sinks maybe?). If anyone could help me figure out what's wrong, that would be fantastic, since the TV is now out of warranty and it'll cost me $75 just to get it looked at.
  • KH70 Aug 17, 2013
    NB: My description was misleading and I need to clarify, so, here is the post, reworded for accuracy: I have a samsung LN46D630. When I turn it on, the screen will stay on for a few minutes, then shut itself off (the screen is black; I've looked at it in a darkened room and there is no light coming from the screen). I can turn the set off, then turn it back on and the screen will turn on, but it stays on for a much shorter period of time, say 1 minute, before turning itself off again. If I turn the set off and on again, the screen will stay on for just a few seconds, then turn itself off. I've noticed that if I leave it off for a while (for example, overnight), then when I turn it on the next day, the screen will again stay on for 5-10 minutes before turning off. Then the whole cycle starts again (=turn it back on, screen stays on a minute or so; turn it back on, screen stays on a few seconds). The set itself doesn't turn off, since the audio still works; it's just the screen. I have no knowledge of the inner workings of a TV, and the only thing I can say is that I don't think it's the backlight inverter, since I already replaced that. If anyone could help me figure out what's wrong, that would be fantastic, since the TV is out of warranty and it'll cost me $75 just to get it looked at. If any other info would be helpful please let me know, and if I can figure it out, I'll provide it. Thanks.
    Top Expert:
  • Samsung Master
  • 52,423 Answers
Probably a failing power supply
Posted on Mar 09, 2015
SOURCE:
lukster
  • 217 Answers
SOURCE: Turns off by itself 10 minutes after use, and goes on and off
sounds like a main board problem
Posted on Apr 30, 2007
  • 197 Answers
SOURCE: SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Posted on Jun 07, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
  • 4 Answers
SOURCE: samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Posted on Jan 19, 2010
SOURCE: Samsung LN32A330 turns itself off after 5-10 minutes of being on.
its usually the 2200 microfarad cap on the power board that stops working. its really easy to replace and its only a 5 dollar repair part. use a 2200 mF cap rated around 25 volts instead of the usual 10 volts. samsung is famous for bad caps. if the cap feels buldged than this is the problem
Posted on Mar 30, 2010
Samsung LN46D630 screen flickers
The Tcon board or the LCD pnle is faulty ,can confirm by replacing the Tcon board. If you wish to get some more information about Tcon board problems and solutions then check the following link.
http://electro-medical.blogspot.com/
Oct 03, 2016 | Samsung LN46D630 LCD TV
Replacing the video chip
It is not easy to replace video chips at the main board. It is almost impossible. The best way to replace the entire board as card basis.
Sep 12, 2015 | Samsung LN46D630 LCD TV
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Tryning to get a manual for my tv mod. ln46d630
The User manual is available in several places. Crutchfield has a link to the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/305/30540D630.PDF (alternately access it from the Crutchfield product sale page). Samsung also has the manuals but you need to add several extra characters that indicate where the TV was sold. See http://www.samsung.com/us/support/downloads/LN40D630M3FXZA (the link is a javascript link to a Terms of Use page) for the US version.
I hope this helps.
Sep 28, 2011 | Samsung LN46D630 LCD TV
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Feb 01, 2010 | Logitech Harmony 550 Remote Control
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Samsung LN46D630 LCD TV Logo
637 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
