Question about HP LaserJet P1505n Printer
Paper pickup problem - HP LaserJet P1505n Printer
    New Friend:
Turn the main power on E100-0001 on canon image
Posted on Aug 29, 2013
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Blank pages when printing
Altinis:
Remove the paper tray and look up into the paper pickup area. The roller there is the paper pickup roller. Under the paper pickup roller is a paper double-feed prevention pad. Take a "Q-Tip" dipped in alcohol and clean both the paper pickup roller and the double-feed prevention pad. That should prevent the paper double-feeds that you are experiencing.
Feb 24, 2013 | HP Photosmart B110a Wireless e-All-in-One...
My hp laserjet p2015dn printer is not pickup the paper.
The typical cause of failing to pickup paper and paper jams is worn out pickup rollers. These are easy to replace. The kit of pickup rollers and separation pads can be found here:
http://www.ccl-la.com/catalog/product_info.php?products_id=128
Mar 29, 2012 | HP LaserJet P2015dn Printer
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
Error 13.01.00 hp 3005
Thank you for contacting FixYa with your printer inquiry.
This is usually a paper pickup error where paper pickup roller is not contacting the paper in the default paper tray or Pickup roller is worn smooth and not picking up the paper.
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding.
Solutions: Make sure the paper size adjuster in the tray (Paper Backstop) is against the paper and correctly set for paper size.
Paper roller slippage - Needs to be replaced. Order a new one. Clean with water or alcohol in the interim while waiting for replacement. Eliminate all the paper dust. Sometimes works.
Part Number: RL1-1370-000CN Paper pickup roller - Picks up media from the paper input tray.
Venders: http://partsurfer.hp.com/Search.aspx?SearchText=Q7814A - HP Parts Surfer
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet P3005n Printer
Paper not pulling
If the printer is not taking paper out of the tray, most likely the pickup roller is worn out. On some models, the pickup fails if the paper is not properly loaded. For example, if the paper guides in an adjustable tray (permits the use of different paper sizes) are not properly set, the paper may not be correctly positioned for pickup.
If you need more information, please post with your printer's make and model number (such as HP LaserJet 4).
Jan 29, 2011 | Office Equipment & Supplies
Paper won't feed
More than likely you pickup roller is dirty.
You can try to clean to see if that helps.
If that fails, then replace the pickup roller.
Below is a service manual that will show you how to remove and clean the pickup roller and how to replace it if necessary.
LJ1020 Service Manual
  • Pickup roller RL1-0266-000CN 50,000 pages Affects paper pickup
Sep 04, 2009 | HP LaserJet 1020 Printer
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet P1505n Printer Logo
62 people viewed this question
Clive
Clive
