Question about Maytag Atlantis MAV6000 Top Load Washer
How to replace thrust bearing, maytag washer?
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 61 Answers
SOURCE: Replacing maytag thrust bearing kit 12002213
yes you can do it yourself no special tools are need just a couple good flathead screwdrivers and a lot of patiance be sure to put all the new washers and bearing back on in the same order the old ones came off putting the C clip on can be a little tricky but take you time and it can be done you may hvw to use the flat head to pry on the trans. shaft to get the clip in the groove then use a pair of chanell locks or pliers to snap it on if you get a new style bearing it may not look like the one you take off and not have all he washers just snap the small plastic pice onto the bearing put it on the the pulley the most of the time just the thin washe then the C clip the dust cover put belt back on the test machine
Posted on Jan 20, 2009
allbrands
Victoria Gadawski
  • 600 Answers
SOURCE: Where do you get the
Hello, Thank You for using FixYa. I will be helping you today.You dont use the spring tool when replacing the thrust bearing. Only when removing the brake.It can be hard to get on but no special tool needed.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
SOURCE: SUBSTITUTION PART #12002213 FOR ORIGINAL
Try turning the shaft in the agitate direction while pulling, At the same time shove the ring in. If you get it on and its too tight you can TRY a thinner washer but if the machine is noisy or doesnt spin properly there might be a problem with your transmission
Posted on Jul 14, 2011
Gere knutson
  • 842 Answers
SOURCE: replace thrust bearing maytag PAV2300
This link is a picture of the thrust bearing and it's order of how it needs to be replaced. Item number you are looking for is 24.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Oct 11, 2011
Changed belt in maytag washer but there is still a clicking noise
You will need to replace the "thrust bearing" on the bottom of the transmission. Here is the kit to order.
Nov 24, 2012 | Maytag MAV4755A Top Load Washer
Replace thrust bearing maytag PAV2300
I hope this helps
Oct 10, 2011 | Maytag PAV2300 Top Load Washer
Where do you get the tool to compress the spring when replacing Maytag top load thrust bearing? Even with the .032 washer, I can't get it on.
Jun 17, 2011 | Maytag PAV2300 Top Load Washer
My Maytag performa washer will not agitate or go into the spin cycle. It makes a loud noise instead
From what you're describing I suspect the thrust bearing needs replaced. The thrust bearing is what releases the brakes. You will not be able to rotate the basket manually with the brakes set. I recommend replacing the thrust bearing kit part number
Jan 10, 2011 | Maytag Washing Machines
I have the MAYTAG top loader washer, Model #MAV6451AWW, it will not spin in the rinse cycle, how to fix / take apart?
Usually when this unit washes but will not spin the thrust bearing kit is damaged.This is easy to repair with little cost.
Completly empty the unit, clothes and water ,unplug the power cord, lie the unit on its back, remove the belt,the c clip from the pully. Take the thrust bearing,the pully the washers off the unit . Grease the new bearing and install new parts. I would also replaced the belt.
Feb 06, 2010 | Washing Machines
Maytag PAV2300 - Washer agitates during wash. on spin cycle motor runs and belt is fine, but drun does not spin. Water drains. Why does it not spin?
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Maytag PAV2300 Top Load Washer
Clutch on a maytag
no this machine has a thrust bearing not a clutch if the machine is not spinning well you need to replace the thrust bearing kit it come with a new drive pulley
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Nov 03, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Motor pulley
bshu, first get yourself a bunch of rolled towells or something of that nature to place between the tub and rear cabinet. This way when you lean it back the pulley will stay centered with the hole. Remove the cap to the thrust bearing, it just pops off. You will see a lock ring sitting on washers. You can remove this with a flat blade screw drive and the cam will come off. Pull down on the pulley but be carefull to remember the order of the washers and bearings. If you are going to replace the thrust bearing kit, the part number is 12500036 series 12. This kit will come with a new pulley. After you have installed the new kit, getting the last retaining clip on can get frustrating. It is tight and you may need a third hand...hope this gets you going.
Jun 12, 2006 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
117 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
