Question about Kyocera FS-4000DN Laser Printer
Kyocera printer says cassette not loaded but it is
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
Make sure dial on front of cassette matches paper size in cassette
Posted on Feb 01, 2019
    New Friend:
    Problem Solver:
  • 5 Answers
Chekc what the printer really asked. Sometime it is letter format or letterhead or something like that.
When the paper in the cassette is defined as "normal" and "A4" and you send "Letter" or "thick" then it asked for paper also.
Most people don't see this. They see only Add Paper on display.
Posted on Jun 13, 2019
    New Friend:
For the paper size to be recognised you need to adjust the roller from the front of your paper tray to the desired size.
Insert the paper and if the problem persists, you'll need to consider applying the following temporary fix:
Locate the 3 spring clips on the insert section of your printer where the paper tray slides in. The 3 springs will be on the side where the paper size can be adjusted on your printer tray.
Apply cellotape over the springs ensuring they are fully pressed and then re-insert the tray.
The clips are what helps your printer determine the paper size in your tray. Rotate the paper size roller on the tray and notice how the notches change, each turn will allow the notch to press the relevant spring clips inside the printer.
Mighty Yaz
Kyocera printer says cassette not loaded but it is - kyocera cassette not loaded-aiju0tdcvtyxyobw2y2lwrii-4-0.jpg
Posted on Mar 26, 2019
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 25 Answers
SOURCE: Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Posted on Jan 07, 2009
ayubkhan2239
Ayub Khan
Very helpful thanks a lot
Posted on Sep 21, 2017
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 08, 2009 | Office Equipment & Supplies
J-11
J11 is telling you that the copy paper has not fed from the 1st paper cassette under the machine.This may be due to incorrectly loaded paper,cassette requires adjusting or the feed roller requires cleaning.The feed roller sits in the machine and you will need to unplug the copier and remove the paper cassette to gain access,Clean the roller with lint free rag and spray and wipe.
Oct 07, 2009 | Kyocera KM-1505 Copier
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Print out landscape
Make cassette number 1 8 X 11. Load paper portrait in tray 1
Mar 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Dec 16, 2008 | Kyocera FS-4000DN Laser Printer
Kyocera load a casset
check the paper size dial on the left inside of cassette draw.
May 04, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-4000DN Laser Printer Logo
3,849 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
