Question about Canon imageRUNNER 6000 Copier
Error E000001-0000 I have a Canon Copier Imagerunner 6000 that is giving this error: Turn the main power switch off and on again ... Error code: E000001-0000
  • Anonymous Mar 21, 2014
    not working any code
  • 66 Answers
E001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Posted on Apr 23, 2009
Canon ir 6000 ranning copy machine hang 2minet before e733
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
Feb 07, 2015 | Canon imageRUNNER 6000 Copier
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
Error code e542
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Apr 18, 2009 | Canon imageRUNNER 6000 Copier
When i turn on my canon C2620, it gives me the error E000001-003
what is the error code it is giving?? write it down and re submit it
Mar 18, 2009 | Canon imageRUNNER 5570 Copier
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 6000 Copier Logo
8,367 people viewed this question
Clive
Clive
old marine
old marine
