Question about Kodak EASYSHARE Z1285 Digital Camera
When I turn the camera on, immediately it goes off. The lens is all the way out and won't retract. I have held the 'on' button down, but that doesn't help. It will not turn on. I have fresh batteries.
Kodak Easy Share Z1285 turns on for a second then goes off. The lens is all the way out and doesn't go back in when shut off. I repeatly turned it on, butit goes off. I kept holding down the turn on button ... but that doesn't help.
  • 1 more comment
  • Anonymous May 11, 2009
    sAME PROBLEM--CHANGING BATERIES NO HELP WONDER IF i SHOULD HAVE TO CHANGE DATE, TIME , MONTH, YEAR BEFOR EE CAMER A WILL START WORKING RIGHT?
  • ischank May 20, 2009
    Same problem. Lens fully extended and won't retract. When I hit power button, it activates the LCD screen for a couple seconds on the reset Date/Time screen, then shuts off.
  • Jesse Mc cartney Aug 10, 2013
    you can pull the lens to get it open temporarily but i don't know how it's repaired permanently :(
  • 6 Answers
Push on the front of the lens when you turn it on. The lens extended to far and doesn't have enough power to close it back.
Posted on Jun 05, 2009
  • 31 Answers
Ok I have the same problem but i notice when i put in my 8Gig sd card that same thing happens so i just use my 2 gig sd works fine also the battiers area help too i change them to new duracells. I hope this works for you guys.
Posted on Jun 25, 2009
  • kevlarr33
    kevlarr33 Jun 25, 2009
    So let me clear it up. I did some research and on Kodak's website they say they recommend up to 2 gig on regular SD and their Kodak brand 8 gig SD/HC I bought an off brand 8 gig that does not work! My 2 gig SD is Kingston Works great.
THANK YOU, THANK YOU, THANK YOU! I JUST SPENT OVER AN HOUR ON THE PHONE WITH KODAK AND THEY WANTED ME TO SEND IT IN FOR REPAIR AT THE COST OF $100 PLUS DOLLARS OR BUY A NEW CAMERA! THIS WORKED IMMEDIATELY...AGAIN, THANK YOU FOR TAKING THE TIME TO POST THIS SOLUTION!
SOURCE:
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out fine...except...it doesn't retract completely flush with the barrel of the lens. Is this a big problem?
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Aug 26, 2012 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Lens retracts when turned on
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot A75 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
493 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
